ha on wlc with sso
I have two questions regarding a setup of two 5508 controllers. Both are configured in ap-sso mode with an ssid "NYLK" configued.
a) since ap-sso is configured , do we still need to use the high availability field in each individiual ap's as they appear on the wlc?
    what is the difference between ap-sso & high availabilty field seen within each ap when online on the controller.
b) The dhcp pool is setup on the core switch , to which both controllers are connected.
    To test NYLK ssid, should we just put the core switch ip address under the dhcp server field in the NYLK interface or is something else to be done?
   I want the users to get ip address when connected to NYLK & test connectivity.
Please advise with inputs. Thanks in advance.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
ha on wlc with sso
If you only have TWO WLC and the second WLC is configured as the redundant pair of HA SSO, then the answer is NO.
If, however, you have another WLC (or a pair of HA SSO WLC) then you can still use this.
Make sure the allowed-vlan is enabled on the 2nd pair of HA SSO.
ha on wlc with sso
ha on wlc with sso
151
