Silver
Hard reset on a Cisco Ap 1130AG doesnt work
Hi, I got a problem with a ap that I have here where I do not have the password and I did the process to reset the AP to factory defaults, but the configuration still the same, and the AP still asking for the enable password, its the same problem poused before in this link https://supportforums.cisco.com/thread/2030572 I did the same process but I still have the old configuration on the AP. I noticed that the AP change the image when I reset the AP, using the mode button. the AP is starting with and rcv image: flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx. Can someone give me and hand with this? I need to reset the AP to its initial configuration. Like new, but the regular process con the cisco website does not work, this is the show flash command:
CAGBLNSW102>sho flash
Directory of flash:/
2 -rwx 525184 Jan 27 2009 18:01:20 +00:00 r0.rcore
3 -rwx 6168 Mar 01 2002 00:00:32 +00:00 private-multiple-fs
4 drwx 128 Jan 01 1970 00:01:58 +00:00 c1130-rcvk9w8-mx
14 drwx 320 Dec 05 2010 08:49:59 +00:00 c1130-k9w8-mx.124-21a.JA2
7 -rwx 165 Jan 01 1970 00:00:47 +00:00 env_vars
9 -rwx 4328 Dec 05 2010 09:22:18 +00:00 event.log
15998976 bytes total (8627712 bytes free)
CAGBLNSW102>
Please help I dont know what to do... thanks,
Daniel
Posted by WebUser Daniel Nigrinis from Cisco Support Community App
Hall of Fame Super Gold
Default username/password is "Cisco/Cisco".
Silver
No I have done that already but the AP still have the old configuration. Check the hostnemae, i still asking for the old password...
Using a TFTP Server to Return to a Previous Release
The process will cause your WAP to go into factory-default.
If trying with the mode button and loading the image from the TFTP with ip in the range 10.0.0.2 - 10.0.0.3 described in the link mentioned above you can try to download the IOS image from ROMMON.
Check the following link:
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1048378
1060
