Help! AP 1262 cannot Join Cisco WLC 4402
We have two cisco 1262 AP and a 4402 WLC, the AP cannot join the WLC.
The AP gets the address from dchp
I cannot ping the AP address from the WLC, but i can ping the default gateway and other VLAN addresses.
I already read the info on the this link :
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
Still our AP cannot join the WLC no matter what i have tried.
Can anyone help with this problem?
Setup
- VLAN setup on a Cisco 3560 48 port poe Switch
- tunk configured btwn the Gi Interface and the Management physical port
- WLC mode is configured for Layer 3
- AP Manager and Management are in the same Subnet
- Option 43 is configured for the with the AP Manager's  IP address
- Opotion 60 is also configured with  AP Manager's  IP address
- the port connected to the APs are in the AP Manager VLAN
Please help.
Thanks!
Everyone's tags (4)
1 ACCEPTED SOLUTION
you atleast need code 7.0.116.0 on your WLC for 1260 to join. the latest available and supported code on 44XX is 7.0.235.0. Check the appropriate release notes for code upgrade path.
Product Version.................................. 4.2.61.0
Hall of Fame Super Gold
Please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WAP:  sh version;
3.  WAP:  sh inventory
VH.SAT.AP1-1262>sho ver
Cisco IOS Software, C1260 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
ROM: Bootstrap program is C1260 boot loader
BOOTLDR: C1260 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
VH.SAT.AP1-1262 uptime is 3 minutes
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1262N-N-K9    (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FTX1616E48X
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 2C:54:2D:9E:02:DE
Part Number                          : 73-12175-05
PCA Assembly Number                  : 800-32268-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16140D19
Top Assembly Part Number             : 800-33866-01
Top Assembly Serial Number           : FTX1616E48X
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1262N-N-K9
Configuration register is 0xF
VH.SAT.AP1-1262>
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
RTOS Version..................................... 4.2.61.0
Bootloader Version............................... 4.0.219.0
Build Type....................................... DATA + WPS
System Name...................................... VH-SAT-4400
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.1.99.5
System Up Time................................... 0 days 15 hrs 35 mins 36 secs
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
--More-- or (q)uit
Number of WLANs.................................. 2
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:18:B9:EA:91:00
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Re: Help! AP 1262 cannot Join Cisco WLC 4402
This is one reason why your WAP won't join the controller.
You have two different regulatory domain.  If the WAP is going to be used in America, then the regulatory domain should be "A".
Have a look on the link below to know which regulatory domain you should be using.
Wireless LAN Compliance Status
This is the OTHER reason why your WAP won't join the controller.
Bronze
You cannot ping the AP from the WLC. That is the problem. Can you ping the AP from other workstations in different subnets? Can the AP get default GW from dhcp?
yes i can ping the AP from a other workstation in a difernet network.
I changed the WLC to layer 2 and changed the option 43 ip address to the management address, with this, I can ping the Management Interface IP address and other subnet from the AP, however i cannot ping the AP address from the WLC
I also manually configured the the AP with the controller address
lwapp ap controller ip address 10.1.99.5
still no success
. I can ping from the AP all the differnet subnets
I can ping from a workstation on a different subnet to the AP
I can ping from the WLC to other subnet
I cannot ping the AP from the WLC.
Thanks all.
I have tried to upgrade the code on the WLC 4402 and it says "This code is not supported."
4.2.209.0 or later 4.2 release
You can upgrade directly to 7.0.235.0
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_235_0.html#wp784219
Your versoin is 4.2.61.0. This is not "4.2.209.0 or later", right? So you can not do direct upgrade.
upgrade first to 4.2.209.0 then go to 7.0 code.
Don't forget to take backup from your config before the upgrade.
Amjad
Rating useful replies is more useful than saying "Thank you"
You are correct.
Thanks.
Step one: Read this link : http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
Next complete the following checklist:
1. make sure code support the AP
   link: http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_235_0.html#wp784219
2. if not, upgrade the code.
  Note use tftpd32 server, because tftp solarwind will not support such a large file.
   link: http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
3. If the AP still does not join the WLC, configure AP priming with the WLC management IP address
   link: http://wirelessccie.blogspot.com/2009/08/configure-your-lwapp-ap-from-ap-cli.html
Putting it all together
1.config vlan
My Example:
vlan 2
name Mgmt-AP-Vlan
2. config vlan interface
My Example:
int vlan 2
  ip address 172.1.2.2 255.255.255.0
  description Mgmt Vlan
   ip default-gateway 172.1.2.1
  end
int vlan 3
  ip address 172.1.3.2 255.255.255.0
  description GuestWLAN Vlan
   ip default-gateway 172.1.3.1
  end
3.configure Trunk
en
config t
interface GigabitEthernet0/1
description ***TRUNK CONNECTION TO WLC4400 Port 1***
switchport mode trunk
switchport trunk allowed vlan all
no shut
4. Configure DHCP with option 43
  link: http://www.cisco.com/en/US/docs/wireless/access_point/1200/installation/guide/120h_g.html#wp1007845
My Example:
ip dhcp pool Mgmt-AP-Vlan2
   network 172.1.2.0 255.255.255.0
   default-router 172.1.2.1
   dns-server 10.1.10.252 10.1.10.251
   option 60 ascii "Cisco AP c1262"
   option 43 hex f104
   domain-name localdomain.com
ip dhcp pool GuestWirelessWLAN3
network 10.1.66.0 255.255.255.0
default-router 172.1.3.1
option 150 ip 172.1.2.5
option 60 ip 172.1.2.5
!172.1.2.5 is the WLC management IP address
exit
I think it is not necessarily to be 7.0.116.0 or later. I think it should work with whatever 7.0. for example; 7.0.98.0 or 7.0.98.218 still support this AP.
3973
