Help, I can?t apply WLAN through WCS
Hello folks
I?m using WLC 4402 (v.4.0.206.0) with WCS 4.0.81.0
When I create a new WLAN template in WCS and try and apply it to my controller I get this error reason: "SNMP operation to Device failed: Set for this object is not supported anymore"
Why is this happening ?
Re: Help, I can?t apply WLAN through WCS
Upgraded WCS to 4.1.83.0, this solved the problem.
Good find. Thank you for sharing the thread. The WCS should be close to the same software version as your controller to get the best operability.
352
