Community Member
Help me ! AP AIR-CAP1552E-E-K9 not join controller 5508
hello,
Please I need help. I have a 5508 and AP 1552 controller.
APs take an IP address dynamically via DHCP (WLC 5508), but fails to join the controller.
Here below some out put which can enlighten you. thank you
--AP----------SH VERSION----------------------------------
Cisco IOS Software, C1550 Software (C1520-K9W7-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 05:12 by prod_rel_team
ROM: Bootstrap program is C1550 boot loader
BOOTLDR: C1550 Boot Loader (C1520-BOOT-M) LoaderVersion 15.2(2a)JA, RELEASE SOFTWARE (fc1)
ap uptime is 25 minutes
System returned to ROM by power loss
System image file is "flash:/c1520-k9w7-mx.152-2.JB/c1520-k9w7-xx.152-2.JB"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1552E-E-K9    (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1715H019
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power loss
AVR Microcontroller 1 - SW Version: 00.01.02
AVR Microcontroller 2 - SW Version: 00.01.09
AVR Microcontroller 6 - SW Version: 00.01.00
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F0:29:29:C2:98:20
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC1705595U
Top Assembly Part Number             : 800-34853-05
Top Assembly Serial Number           : FCZ1715H019
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552E-E-K9
Configuration register is 0xF
--AP-------sh ip int br------------
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.10.10.13     YES DHCP   up                    up
Dot11Radio0                unassigned      YES unset  administratively down down
Dot11Radio1                unassigned      YES unset  administratively down down
GigabitEthernet0           unassigned      YES TFTP   up                    up
GigabitEthernet1           unassigned      YES unset  up                    down
GigabitEthernet2           unassigned      YES unset  up                    down
GigabitEthernet3           unassigned      YES unset  up                    down
--AP------sh inventory--------------
NAME: "AP1550", DESCR: "Cisco Aironet 1550 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP1552E-E-K9 , VID: V04, SN: FCZ1715H019
(Cisco Controller) >SHow sysin
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.100.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... WLC-EEML
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.10.10.1
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 23 mins 5 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... FR  - France
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
External Temperature............................. +24 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ E0:2F:6D:5D:7D:C0
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 25
(Cisco Controller) >SHow TIME
Time............................................. Mon Jan  6 13:07:29 2014
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index                  NTP Server                  NTP Msg Auth Status
THX
2 ACCEPTED SOLUTIONS
VIP Purple
Hi , Yes u must use use .tar:
archive download-sw/overwrite/force-reload tftp:////
AP#archive download-sw /force-reload /overwrite tftp://10.10.10.200/c1520-k9w8-tar.152-4.JB3.tar
VIP Purple
Cisco Wireless LAN Controller Field Upgrade  Software (FUS) is a special AES package that performs various  system-related component upgrades. We recommend that you install the FUS  image to upgrade components such as the bootloader, field recovery  image, FPGA/MCU, and other firmware to their latest respective versions.
Please check this:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/fus_rn_1_7_0_0.html
VIP Purple
Re: Help me ! AP AIR-CAP1552E-E-K9 not join controller 5508
Last reload reason:
You have autonomous image on AP.
You must change the image on AP to leightweight IOS.
How to convert it:
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Reagrds
Community Member
Thank's for your help
could you tell me the link where I can find one for IOS AP 1500 SERIES?
for I see that for 1600 and others but not for 1500;
THANKS
VIP Purple
you can download fro here , if you have service contracrt:
http://software.cisco.com/download/release.html?mdfid=283791419&flowid=24862&softwareid=280775090&release=15.2.4-JB3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
If yuou dont have service contract then contact to ur supplier may be he can provide u the Leightweight ios.
Reagrds
dont forget to rate helpful posts.
Community Member
Hi Sandeep, AP AIR-CAP1552E-C
Hi Sandeep,
AP AIR-CAP1552E-C-K9 does support controller 5760 ? If support then how can I join this controller.
I have search documents but here it is not support to IOS XE
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
K9w7 is the indication it's autonomous. You need the k9w8
Here is a link about Cisco wifi images
https://supportforums.cisco.com/docs/DOC-19607
VIP Purple
you need Leighweight IOS: c1520-k9w8-tar.152-4.JB3.tar
Download from here:
Dont forget to rate helpful posts
Community Member
Thank's for the link,
Now, I try to change the ios and I come to you
Hall of Fame Super Silver
You might as well download the WLC code FUS images also.....
Your WLC code does not show the correct FUS
http://software.cisco.com/download/release.html?mdfid=282600534&flowid=7012&softwareid=284364857&release=1.7.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest
-Scott
Community Member
Please i dont understande what is th FUS?
I downloaded the file: c1520-k9w8-tar.152-4.JB3 on the cisco site.
1552 AP has a dynamic IP address and ping from my PC successfully
the command :archive download-sw /force-reload /overwrite tftp://10.10.10.200/c1520-k9w8-tar.152-4.JB3  fails.
there is an other way?
thx
VIP Purple
Community Member
Hello!!
the name of the IOS: c1520-k9w8-tar.152-4.JB3. should I rename the archive with the extension. tar? because when I try with this name it does not succeed.
another question, the folder contains multiple files is that this is not one of them that I have to extract to change the ios?
thank you for your help
VIP Purple
Community Member
thank's it's OK,
but the AP does not associate itself Forever.
the AP, these messages appear:
*Jan  7 11:03:40.103: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan  7 11:03:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.10.1 peer_port: 5246
*Jan  7 11:03:40.491: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.10.1 peer_port: 5246
*Jan  7 11:03:40.495: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.10.1
*Jan  7 11:03:40.495: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan  7 11:03:40.495: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan  7 11:03:40.495: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan  7 11:03:40.495: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.10.10.1
*Jan  7 11:03:45.491: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.10.1
*Jan  7 11:03:52.655: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Jan  7 11:03:52.655: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Jan  7 11:03:52.655: %MESH-6-LINK_UPDOWN: Mesh station f029.29c2.983c link DowN
VIP Purple
Hi ,
you have to add AP ethernet mac address onto WLC mac-filter data base (under Security -> MAC filtering)  & then allow AP to register in mesh mode. You can add this entry via WLC CLI as well. Here is the full CLI command syntax
(WLC) >config macfilter add [interface name] [description] [Client IP address]
Once you do this your AP should  register to WLC in mesh mode. Then  you can convert it to local mode via  WLC GUI or CLI.
Here is the CLI way of doing it
(WLC) >config ap mode local submode none
and
Did u upgradeed the FUS image on wlc:
Reagrds
Community Member
Once again thank you for your support,
For FUS, I do not understand what it is, please can you explain me what is brief?
I will install the version without LDPE
I'll download and update.
Community Member
hi Scott and et all
i see trouble on cisco 1552sa
Jan 13 21:29:30.843: %CDP_PD-2-POWER_LOW: 802.11N 2.4GHz Radio0 disabled - NEGOTIATED WS-C3750X-24P (24e9.b3f5.1202)
now i just 802.11 a/n up but 802 b/g/n is disable
I use switch 3750x poe to supply power to cisco 1552sa
help me slove this
Thanks so much
VIP Purple
Hi Nguyen,
This message indicates the access point is in low power mode and radio disabled because the Cisco power source has indicated it is not capable of supplying sufficient power to the access point.
It is always recommended to use 1500 power injector to power these APs.
"To provide inline PoE, you must use the 1500 power injector (AIR-PWRINJ1500-2=). Other power injectors, PoE switches, and 802.3af power sources cannot provide adequate power, which may cause the access point to malfunction and cause possible over-current conditions at the power source."
Above is forom the 1550 getting started guide
http://www.cisco.com/en/US/docs/wireless/access_point/1550/quick/guide/ap1550qsg.html#wp50784
Can you paste the output of sh inventory from AP:
Did you add mac address of AP in Mac filter ?
Community Member
Dear You
this is result from AP 1552SA
APdca5.f4b8.fa20#show  inventory
PID: AIR-CAP1552SA-E-K9, VID: V02, SN: FGL1747Y00H
Mac added to Macfilter and AP joined controller
I just only 802.11 a/n  up but 802.11 b/g/n down
VIP Purple
Can you go to wireless>All APs then click on your AP and then make admin status Enable.
Also paste the sh version from AP.
Sh sysinfo from WLC.
Community Member
Dear you
wireless > All APs : ok admin status enable
show version from AP
export@cisco.com.
cisco AIR-CAP1552SA-E-K9 (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FGL1747Y00H
Last reset from reload
LWAPP image version 7.5.102.0
2 802.11 Radios
Base ethernet MAC Address: DC:A5:F4:B8:FA:20
PCB Serial Number                    : FOC17300Q4D
Top Assembly Part Number             : 800-35281-02
Top Assembly Serial Number           : FGL1747Y00H
Product/Model Number                 : AIR-CAP1552SA-E-K9
Show sysinfo
Product Version.................................. 7.5.102.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console        2.2
System Name...................................... Cisco5500
IP Address....................................... 10.10.2.254
System Up Time................................... 8 days 15 hrs 20 mins 18 secs
Configured Country............................... VN  - Vietnam
--More-- or (q)uit
Internal Temperature............................. +41 C
External Temperature............................. +29 C
Burned-in MAC Address............................ E4:C7:22:AA:EC:40
VIP Purple
I can not find the exact cause:
Can you use Power injector for this AP ?
If yes then also check Power injector state on Wireless>AP >Advnaced page.
Just to double check with you the admin status is enable please verify
on the  Wireless >All APs> Detail > 802.11b/g/n Cisco APs >
Configure > Admin Status.
Is the 802.11g and 802.11b/g enabled?
Please go to WIRELESS > 802.11b/g/n > Networks > 802.11g Support /
802.11b/g Network Status > Enabled.
Community Member
Hi you
Ok sure enabled
if you effort use switch PoE 802.3af to supply power to 1552SA OK ?
VIP Purple
1552SA
• 100-240 VAC, 47-63 Hz
• 12 VDC
• 47 W
Note: The power consumption above does not include powering an external PoE (802.3af) device; allow for an additional 20 W. If using fiber SFP backhaul, add an additional 1 W.
Now I feel that u must use power injector for this AP.
Community Member
OK
Thanks so much
I will purchase power or injector
VIP Purple
Please check this:
Community Member
THANK'S FOR YOUR HELP,
VIP Purple
Glad that finally u resolved ur issue.
Thanks for rating.
Community Member
Hi All
Current i have 2 option config authentication:
Option 1: Config Radius server on winserver 2012 and controller relay to raidus
But have a proble that all laptop installed window system tha not join domain dont connect to WiFi
Option 2: Config use LDAP on server 2012 to authenticate
but i m not successful
do you have file step by step config LDAP on server 2012 to connect controller 5508
3006
