Help me ! AP CAP 3602 + 1552SA not join controller 5508
I am config case study as this diagram and see problem that AIR-CAP3602I-E-K9 and AIR-CAP1552SA-E-K9 do not join controller 5508
File config as below
1. Switch core 3750
IP routing
vlan 5
name wifi
vlan 10
name server
interface range gi 1/0/1-2
sw mo access
sw access vlan 5
interface gi 1/0/4
sw mo access
sw access vlan 10
interface vlan 5
ip add 172.16.32.1 255.255.224.0
dns-server 172.16.1.5 8.8.8.8
interface vlan 10
ip add 172.16.1.1 255.255.255.0
interface gi 1/0/3
ip add 10.10.1.1 255.255.255.0
no shut
no sw port
interface gi 1/0/24
ip add 192.168.1.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip dhcp pool vlan5
network 172.16.32.0 255.255.224.0
default-router 172.16.32.1
domain-name chn.edu.vn
option 43 ip 10.10.1.254
2.AD+ DNS server
Set IP 172.16.1.5
Domain: chn.edu.vn
creat host: CISCO-CAPWAP-CONTROLLER.chn.edu.vn
                IP 10.10.1.254
3.On controller 5508
Enter Administrative User Name (24 characters max): admin
Enter Administrative Password (3 to 24 characters): *****
Default values (admin or Cisco or its variants) in password is not allowed.
Enter Administrative Password (3 to 24 characters): ********
Re-enter Administrative Password                 : ********
Service Interface IP Address Configuration [static][DHCP]: static
Service Interface IP Address: 10.10.2.254
Service Interface Netmask: 255.255.255.0
Enable Link Aggregation (LAG) [yes][NO]: no
Management Interface IP Address: 10.10.1.254
Management Interface Netmask: 255.255.225.0
Management Interface Default Router: 10.10.1.1
Management Interface VLAN Identifier (0 = untagged): 0
Management Interface Port Num [1 to 8]: 1
Management Interface DHCP Server IP Address: none
Enable HA (Dedicated Redundancy Port is used by Default) [yes][NO]: no
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: none
Network Name (SSID): CDCDHaNoi
Configure DHCP Bridging Mode [yes][NO]: yes
Warning! Enabling Bridging mode will disable Internal DHCP server and DHCP Proxy feature.
May require DHCP helper functionality on external switches.
Allow Static IP Addresses [YES][no]: yes
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code list (enter 'help' for a list of countries) [US]: US
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
Configure a NTP server now? [YES][no]: no
Configure the system time now? [YES][no]: yes
Enter the date in MM/DD/YY format: 01/04/14
Enter the time in HH:MM:SS format: 14:39:10
From AP i can ping the IP of controller or name " CISCO-CAPWAP-CONTROLLER " successful
But current AP not join controller
I show log on ap as follow:
*Nov 15 15:11:26.331: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Nov 15 15:11:26.423: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 15 15:11:27.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 15 15:11:36.551: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.10.2.254 obtained through DHCP
*Nov 15 15:11:36.551: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
AP78da.6ef2.3132#
Not in Bound state.
*Nov 15 15:12:32.055: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Nov 15 15:12:37.071: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Nov 15 15:12:37.179: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.37.54, mask 255.255.224.0, hostname AP78da.6ef2.3132
*Nov 15 15:12:43.055: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.10.2.254 obtained through DHCP
*Nov 15 15:12:43.055: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Not in Bound state.
*Nov 15 15:13:28.555: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Nov 15 15:13:33.575: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Nov 15 15:13:33.675: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.37.55, mask 255.255.224.0, hostname AP78da.6ef2.3132
Please help me solve  this
Deeply thanks so much
2 ACCEPTED SOLUTIONS
VIP Purple
Re: Help me ! AP CAP 3602 + 1552SA not join controller 5508
Procedure to change country cod eon WLC:
By CLI:
Before change the country code on wlc , You must disable
WLC > config 802.11a disable network
WLC  >config 802.11b disable network
WLC  >config country SA (...or wtever country u are in)
And then enable both network again.
WLC  >config 802.11a enable network
WLC  >config 802.11b enable network
By GUI:
First disable both network 802.11a and 802.11b
Follow these steps to disable the 802.11a and 802.11b/g networks as follows:
  • Choose Wireless> 802.11a/n > Network.
  • Unselect the 802.11a Network Status check box.
  • Click Apply to commit your changes.
  • Choose Wireless > 802.11b/g/n > Network.
  • Unselect the 802.11b/g Network Status check box.
Change country code on WLC now:
Choose Wireless > Country
Dont forget to rate helpful posts
VIP Purple
I think u need do to do:
MAC needs to be added to the macfilter on the WLC. Add the MAC address of the MAP to the MAC filter table. In order to do this, choose security > AAA > Mac Filtering > Mac Address
Once the AP joins, you can change it back to local mode.
VIP Purple
AP78da.6ef2.3132#
Not in Bound state.
Your WLC is set to country US then your APs must be in -A- regulatery domain.
But botyh AP are in -E- (Europe)domain.
Change the country code on WLC.,
Which country ur wlc is in???
Dont forget to rate helpful posts.
Thanks Sand
Im in VietNam
i intend to change country code from us to VN or French
is it correct
VIP Purple
Yes Right!
If u have country for Vietnam then choose it.
Don't forget to rate helpful posts
VIP Purple
By CLI:
By GUI:
Thanks so much
Current, Cisco 3602 OK but Cisco outdoor 1552SA not join controller.
This is log in 1552SA
Jan  5 12:04:34.579: %CAPWAP-5-SENDJOIN: sending Join Request to 1*Jan  5 11:52:12.579: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.2.254
*Jan  5 11:52:12.583: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan  5 11:52:12.583: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan  5 11:52:12.583: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan  5 11:52:12.583: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.10.2.254
*Jan  5 11:52:17.579: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.2.254
*Jan  5 11:53:11.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.2.254:5246
*Jan  5 11:53:12.035: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jan  5 11:53:22.095: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jan  5 11:53:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.10.2.254 peer_port: 5246
*Jan  5 11:53:22.579: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.10.2.254 peer_port: 5246
*Jan  5 11:53:22.579: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.2.254
*Jan  5 11:53:22.579: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Jan  5 11:53:22.579: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Jan  5 11:53:22.579: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan  5 11:53:22.579: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.10.2.254
*Jan  5 11:53:27.579: %CAPWAP-5-SENDJOIN: sending Join Request to 10.10.2.254
*Jan  5 11:54:07.771: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Jan  5 11:54:07.771: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Jan  5 11:54:07.771: %MESH-6-LINK_UPDOWN: Mesh station dca5.f4b8.f9fc link Down
*Jan  5 11:54:21.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.10.2.254:5246
*Jan  5 11:54:22.039: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Jan  5 11:54:33.087: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Jan  5 11:54:33.087: %CAPWAP-3-ERRORLOG: Invalid event 2 & state 4 combination.
*Jan  5 11:54:33.087: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 4.
*Jan  5 11:54:33.087: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Jan  5 11:54:33.087: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.10.2.254
Is there the difference between method of cap3602 and 1552sa ?
VIP Purple
i am doing that same your idea
well done
do you recommend about config optimal system as i show on the top
ex: roaming, airclean, QoS for user..
i am considering data from user connect to wifi go to controller or go directly to switch core
VIP Purple
Roaming depends on your site survey. If site survey is done properly then there should be no problem for clients .
CleaAir deployment: http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns742/ns982/c07-610746-01_cleanAir_guide.pdf
Qos deployment guide: http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807e9717.shtml
now in my case have Active diretory domain controller + Raidus server
I want to user database of AD to connect WiFi
Ex: in AD has user  Peter pass 1234
I will use user to login WiFi
have you ever config like that ?
and i want set QoS for each user ?
VIP Purple
HI,
To authenticate wifi users, you can use any Protocol : EAP-TLS(certificate needed on both side) or PEAP(username and password).
Please check this link:This is the step by step guide.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080921f67.shtml
Thanks Sandeep , I was also having same issue and resolved with ur guideline
TThanks u ver much
1130
