Help troubleshooting EAP timeout debugs
Hi all,
i have some wireless IPADs which need to be connected to the wireless 24/7 as they run an app which needs to keep refreshing data automatically.
I have managed to capture a debug output of one of the IPAD when they drop off and I can see attempts to re-authenticate the client but it looks like EAP times out.
Is there anywhere I can read to understand more about why this would happen and how to rectify this? We are using EAP-TLS on this particular SSID.
Thanks!
Mario
*apfPmkCacheTimer: Mar 21 11:12:16.238: 60:fe:c5:6b:9a:13 Removing expired PMK cache entry for station 60:fe:c5:6b:9a:13 AKM was:APF_KEY_MGMT_80211i
*apfPmkCacheTimer: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Removing expired PTK entry for station 60:fe:c5:6b:9a:13
*apfReceiveTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Initiating 802.1x due to PMK Timeout Event for STA
*apfReceiveTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Found an cache entry for BSSID f4:7f:35:d8:fa:10 in PMKID cache at index 0 of station 60:fe:c5:6b:9a:13
*apfReceiveTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Removing BSSID f4:7f:35:d8:fa:10 from PMKID cache of station 60:fe:c5:6b:9a:13
*apfReceiveTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Resetting MSCB PMK Cache Entry 0 for station 60:fe:c5:6b:9a:13
*dot1xMsgTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*dot1xMsgTask: Mar 21 11:12:16.239: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 1)
*osapiBsnTimer: Mar 21 11:12:46.126: 60:fe:c5:6b:9a:13 802.1x 'txWhen' Timer expired for station 60:fe:c5:6b:9a:13 and for message = M0
*dot1xMsgTask: Mar 21 11:12:46.127: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*dot1xMsgTask: Mar 21 11:12:46.127: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 2)
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.275: 60:fe:c5:6b:9a:13 Received EAPOL START from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.275: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.275: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 3)
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.277: 60:fe:c5:6b:9a:13 Received EAPOL EAPPKT from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.277: 60:fe:c5:6b:9a:13 Received Identity Response (count=3) from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.277: 60:fe:c5:6b:9a:13 Reached Max EAP-Identity Request retries (3) for STA 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.278: 60:fe:c5:6b:9a:13 Sent Deauthenticate to mobile on BSSID f4:7f:35:d8:fa:10 slot 0(caller 1x_auth_pae.c:3165)
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.278: 60:fe:c5:6b:9a:13 Scheduling deletion of Mobile Station:  (callerId: 6) in 10 seconds
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.278: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Disconnected state
*Dot1x_NW_MsgTask_3: Mar 21 11:12:56.279: 60:fe:c5:6b:9a:13 Not sending EAP-Failure for STA 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 Association received from mobile on AP f4:7f:35:d8:fa:10
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 apfApplyWlanPolicy: Retaining the ACL recieved in AAA attributes 255 on mobile
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 Applying site-specific Local Bridging override for station 60:fe:c5:6b:9a:13 - vapId 1, site 'default-group', interface 'corp-wlan'
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 Applying Local Bridging Interface Policy for station 60:fe:c5:6b:9a:13 - vlan 240, interface id 11, interface 'corp-wlan'
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: Mar 21 11:12:56.875: 60:fe:c5:6b:9a:13 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 STA - rates (7): 150 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Processing RSN IE type 48, length 20 for mobile 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Received RSN IE with 0 PMKIDs from mobile 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Setting active key cache index 0 ---> 8
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 unsetting PmkIdValidatedByAp
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 apfMsRunStateDec
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 apfMs1xStateDec
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Associated to Associated
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 Sending Assoc Response to station on BSSID f4:7f:35:d8:fa:10 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: Mar 21 11:12:56.876: 60:fe:c5:6b:9a:13 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Associated to Associated
*dot1xMsgTask: Mar 21 11:12:56.878: 60:fe:c5:6b:9a:13 Station 60:fe:c5:6b:9a:13 setting dot1x reauth timeout = 1800
*dot1xMsgTask: Mar 21 11:12:56.878: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*dot1xMsgTask: Mar 21 11:12:56.878: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 1)
*pemReceiveTask: Mar 21 11:12:56.878: 60:fe:c5:6b:9a:13 10.129.65.226 Removed NPU entry.
*Dot1x_NW_MsgTask_3: Mar 21 11:13:06.895: 60:fe:c5:6b:9a:13 Received EAPOL START from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:06.895: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*Dot1x_NW_MsgTask_3: Mar 21 11:13:06.895: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 2)
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.927: 60:fe:c5:6b:9a:13 Received EAPOL START from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.927: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.927: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 3)
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.931: 60:fe:c5:6b:9a:13 Received EAPOL EAPPKT from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.931: 60:fe:c5:6b:9a:13 Received Identity Response (count=3) from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.931: 60:fe:c5:6b:9a:13 Reached Max EAP-Identity Request retries (3) for STA 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.932: 60:fe:c5:6b:9a:13 Sent Deauthenticate to mobile on BSSID f4:7f:35:d8:fa:10 slot 0(caller 1x_auth_pae.c:3165)
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.932: 60:fe:c5:6b:9a:13 Scheduling deletion of Mobile Station:  (callerId: 6) in 10 seconds
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.933: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Disconnected state
*Dot1x_NW_MsgTask_3: Mar 21 11:13:11.933: 60:fe:c5:6b:9a:13 Not sending EAP-Failure for STA 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Association received from mobile on AP f4:7f:35:d8:fa:10
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 apfApplyWlanPolicy: Retaining the ACL recieved in AAA attributes 255 on mobile
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Applying site-specific Local Bridging override for station 60:fe:c5:6b:9a:13 - vapId 1, site 'default-group', interface 'corp-wlan'
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Applying Local Bridging Interface Policy for station 60:fe:c5:6b:9a:13 - vlan 240, interface id 11, interface 'corp-wlan'
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 STA - rates (7): 150 24 36 48 72 96 108 0 0 0 0 0 0 0 0 0
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Processing RSN IE type 48, length 20 for mobile 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Received RSN IE with 0 PMKIDs from mobile 60:fe:c5:6b:9a:13
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Setting active key cache index 8 ---> 8
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 unsetting PmkIdValidatedByAp
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 apfPemAddUser2 (apf_policy.c:270) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Associated to Associated
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_4: Mar 21 11:13:12.066: 60:fe:c5:6b:9a:13 Sending Assoc Response to station on BSSID f4:7f:35:d8:fa:10 (status 0) ApVapId 1 Slot 0
*apfMsConnTask_4: Mar 21 11:13:12.067: 60:fe:c5:6b:9a:13 apfProcessAssocReq (apf_80211.c:6309) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Associated to Associated
*dot1xMsgTask: Mar 21 11:13:12.068: 60:fe:c5:6b:9a:13 Station 60:fe:c5:6b:9a:13 setting dot1x reauth timeout = 1800
*dot1xMsgTask: Mar 21 11:13:12.068: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Connecting state
*dot1xMsgTask: Mar 21 11:13:12.068: 60:fe:c5:6b:9a:13 Sending EAP-Request/Identity to mobile 60:fe:c5:6b:9a:13 (EAP Id 1)
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.074: 60:fe:c5:6b:9a:13 Received EAPOL EAPPKT from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.074: 60:fe:c5:6b:9a:13 Received Identity Response (count=1) from mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.074: 60:fe:c5:6b:9a:13 EAP State update from Connecting to Authenticating for mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.074: 60:fe:c5:6b:9a:13 dot1x - moving mobile 60:fe:c5:6b:9a:13 into Authenticating state
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.074: 60:fe:c5:6b:9a:13 Entering Backend Auth Response state for mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.077: 60:fe:c5:6b:9a:13 Processing Access-Challenge for mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.077: 60:fe:c5:6b:9a:13 Entering Backend Auth Req state (id=26) for mobile 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.077: 60:fe:c5:6b:9a:13 WARNING: updated EAP-Identifier 1 ===> 26 for STA 60:fe:c5:6b:9a:13
*Dot1x_NW_MsgTask_3: Mar 21 11:13:12.078: 60:fe:c5:6b:9a:13 Sending EAP Request from AAA to mobile 60:fe:c5:6b:9a:13 (EAP Id 26)
*osapiBsnTimer: Mar 21 11:13:41.926: 60:fe:c5:6b:9a:13 802.1x 'timeoutEvt' Timer expired for station 60:fe:c5:6b:9a:13 and for message = M0
*dot1xMsgTask: Mar 21 11:13:41.927: 60:fe:c5:6b:9a:13 Retransmit 1 of EAP-Request (length 10) for mobile 60:fe:c5:6b:9a:13
*osapiBsnTimer: Mar 21 11:14:11.926: 60:fe:c5:6b:9a:13 802.1x 'timeoutEvt' Timer expired for station 60:fe:c5:6b:9a:13 and for message = M0
*dot1xMsgTask: Mar 21 11:14:11.927: 60:fe:c5:6b:9a:13 Retransmit 2 of EAP-Request (length 10) for mobile 60:fe:c5:6b:9a:13
*osapiBsnTimer: Mar 21 11:14:41.927: 60:fe:c5:6b:9a:13 802.1x 'timeoutEvt' Timer expired for station 60:fe:c5:6b:9a:13 and for message = M0
*dot1xMsgTask: Mar 21 11:14:41.927: 60:fe:c5:6b:9a:13 Retransmit failure for EAP-Request to mobile 60:fe:c5:6b:9a:13
*dot1xMsgTask: Mar 21 11:14:41.928: 60:fe:c5:6b:9a:13 Sent Deauthenticate to mobile on BSSID f4:7f:35:d8:fa:10 slot 0(caller 1x_ptsm.c:546)
*dot1xMsgTask: Mar 21 11:14:41.928: 60:fe:c5:6b:9a:13 Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*osapiBsnTimer: Mar 21 11:14:51.927: 60:fe:c5:6b:9a:13 apfMsExpireCallback (apf_ms.c:591) Expiring Mobile!
*apfReceiveTask: Mar 21 11:14:51.927: 60:fe:c5:6b:9a:13 apfMsExpireMobileStation (apf_ms.c:5604) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Associated to Disassociated
*apfReceiveTask: Mar 21 11:14:51.927: 60:fe:c5:6b:9a:13 Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
*osapiBsnTimer: Mar 21 11:15:01.926: 60:fe:c5:6b:9a:13 apfMsExpireCallback (apf_ms.c:591) Expiring Mobile!
*apfReceiveTask: Mar 21 11:15:01.928: 60:fe:c5:6b:9a:13 Sent Deauthenticate to mobile on BSSID f4:7f:35:d8:fa:10 slot 0(caller apf_ms.c:5698)
*apfReceiveTask: Mar 21 11:15:01.928: 60:fe:c5:6b:9a:13 apfMsAssoStateDec
*apfReceiveTask: Mar 21 11:15:01.928: 60:fe:c5:6b:9a:13 apfMsExpireMobileStation (apf_ms.c:5736) Changing state for mobile 60:fe:c5:6b:9a:13 on AP f4:7f:35:d8:fa:10 from Disassociated to Idle
*apfReceiveTask: Mar 21 11:15:01.928: 60:fe:c5:6b:9a:13 Scheduling deletion of Mobile Station:  (callerId: 47) in 10 seconds
*osapiBsnTimer: Mar 21 11:15:11.926: 60:fe:c5:6b:9a:13 apfMsExpireCallback (apf_ms.c:591) Expiring Mobile!
*apfReceiveTask: Mar 21 11:15:11.927: 60:fe:c5:6b:9a:13 pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
269
