Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Help with WLAN on 871W
Hi! I am having troubles with configuring wlan on my 871w. I like to use vlan and a routing table, and no BVI1 or irb. I want to use ACLs later on, and by using irb I could stay with my former linksys wrt54...
This is my config so far: (with 12.4(9)T)
version 12.4
hostname Bxxxxxo
logging buffered 52000 debugging
logging console critical
enable secret 5 $xxxxx0
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp binding cleanup interval 10
ip dhcp excluded-address 192.168.0.1 192.168.0.19
ip dhcp excluded-address 192.168.0.51 192.168.0.254
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp excluded-address 192.168.1.20 192.168.1.254
ip dhcp excluded-address 192.168.2.1 192.168.2.19
ip dhcp excluded-address 192.168.2.51 192.168.2.254
ip dhcp pool dhcp-vlan-private
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
ip dhcp pool dhcp-vlan-guest
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip dhcp pool dhcp-gxxxxxn
import all
host 192.168.0.10 255.255.255.0
client-identifier 01xx.xxxx.xxxx.1a
client-name gxxxxxn
ip dhcp pool dhcp-wlan
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip tcp synwait-time 10
no ip bootp server
ip dhcp-client update dns server both
username Axxxxxn privilege 15 secret 5 $xxxxx1
interface Null0
no ip unreachables
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 20
interface FastEthernet4
mac-address 00xx.xxxx.xxda //I get all IP-information by ISP-DHCP, I just have to spoof my MAC-address.
ip address dhcp hostname Bxxxxxe
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 30 key 1 size 128bit 7 0xxxxxF transmit-key
encryption vlan 30 mode wep mandatory //WEP, because my Palm TungstenC doesn't have WPA.
ssid bxxxxxn
vlan 30
max-associations 5
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.30
encapsulation dot1Q 30 native
no ip route-cache
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.0.1 255.255.255.0
ip helper-address 192.168.0.1
ip nat inside
interface Vlan20
ip nat inside
interface Vlan30
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route 192.168.0.0 255.255.255.0 Vlan10 permanent
ip route 192.168.1.0 255.255.255.0 Vlan20 permanent
ip route 192.168.2.0 255.255.255.0 Vlan30 permanent
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 remark nat-pool
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
end
At the moment I see my wlan on my palm (using http://www.bitsnbolts.com/), but it doesn't connect...
Thanx in advance!
1 REPLY
Re: Help with WLAN on 871W
145
