High Availability Configuration for AP in 5508 with 7.5.102.0
We have recently upgraded the controller to 7.5.102.0. Once the controller is upgraded i tried to change the high availability configuration for the access points. But it fails.
I am not able to set the primary and secondary controller name for the AP in 7.5.102.0
Any Clue?
Thanks & Regards
Sreejith R
  • Getting Started with Wireless
Hall of Fame Super Gold
What error message are you getting when you do this?  Make sure all your entries do not have a space before, between and after.
Re: High Availability Configuration for AP in 5508 with 7.5.102.
It's giving error in setting controller name. I am just changing from controller 1 to controller 2. No issue with space
VIP Purple
Post the WLC CLI output of "show ap config general "  command for one of your AP. If nothing is configured  for HA or HA configured value to be changed, try the below CLI commands for that AP & see what error message you got on CLI
(WLC ) >config  ap secondary-base
(WLC ) >config  ap primary-base
Rasika
**** Pls rate all useful responses ****
Dude,
You are NOT helping.  The error message is very specific.
I will repeat my question again:  What is the EXACT error message?
Did you move the WLC 1 details into WLC 2 and leaving WLC 1 blank?
If you trying to change the setting from an AP template on the Cisco Prime, you might have a Google chrome Issue.
Try to configure it directly on the WLC.
259
