How can i setup Wireless connection with router
hi all,
i have 2650 router and 295o cisco switch at home.
i want to setup wireless connection for laptops?
which hardware should i buy for this setup
thanks
mahesh
Hall of Fame Super Gold
Re: How can i setup Wireless connection with router
mahesh18 wrote:
hi all,
thanks
mahesh
You need a Wireless Access Point (WAP).
hi
thanks for reply
do you know which WAP  model i should buy that is compatible with my switch 2950  and router 2650?
thanks
mahesh
Any wireless access point (WAP) is compatible.  Just be specific if you want to purchase a Lightweight Access Point or an Autonomous Access Point (aAP).  The difference between the two is the IOS run and it's functionality.  If you ordered one by mistake, it's no biggie and it can easily be corrected.
http://www.cisco.com/en/US/products/hw/wireless/index.html
480
