How do I configure a 2702 to be a remote survivable AP
I have a 2504 controller and three 2702 APs.  What I am looking for is documentation on how to ensure that if I have a controller failure (since I have only one), that the APs will continue to serve the WLANs independently of the controller.  We are using WPA2 keys which should be fine, but we also have one guest network that utilizes the controller's Webauth page (passthrough mode to merely accept T's and C's) to authenticate clients.  We would like that to also failover to the APs in the event of a controller failure.  Any direction would be most appreciated.
VIP Purple
You have to simply configure
You have to simply configure AP in Flexconnect mode & your WPA2 SSID to be configured with FlexConnect local switching. So in this case even WLC is down your branch client will operate normally.
Refer this for FlexConnenct design guides
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch7_HREA.html
Central web authentication to work WLC shoud be available & that service will be down as long as WLC is down.
Rasika
**** Pls rate all useful responses ****
Bronze
Hi,please go through the
please go through the below document link.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_flexconnect.html
155
