How do I set WPA key when using 350 Aironet with Netgear DG834GT
Using Aironet Client utility v6.5 with a 350 Mini PCI card on my IBM Laptop.
Trying to connect to my home WiFi that is setup to use WPA - on my other PCs at home I specify a WPA phrase / key when I configure the connection.
BUT there seems to be no way of doing this with Aironet Client utility. The only place I can specify a key is if I use WEP - which I dont think is Secure enough.
My firmware is 5.60.17
Any ideas how I can get this to work?
1 REPLY
Silver
Re: How do I set WPA key when using 350 Aironet with Netgear DG8
EAP/802.1x authentication and dynamic key management, and adds stronger cipher encryption. Once an EAP/802.1x association is made between the client device and the authentication server, WPA key management is negotiated between the access point (AP) and the WPA-compliant client device.
For futher information look at the below URL:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml#background
164
