07-06-2009 09:41 AM - edited 07-03-2021 05:47 PM
How do I telnet into my 4404 controller. I can reach it through its webpage and login but when I type the same IP I used it states I can't connect.
07-06-2009 10:11 AM
Telnet is disabled by default on the controllers. You can enable it under the Management - Telnet/SSH page or with the command "config network telnet enable"
07-06-2009 02:49 PM
Telnet, by default, is disabled. Try SSH. If not do what Dan has described and enable Telnet via HTML or HTTPS.
I do not encourage/recommend unsecure access to the WLC via Telnet and/or HTTP.
Hope this helps.
