Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How do I telnet into my 4404 Controller
How do I telnet into my 4404 controller. I can reach it through its webpage and login but when I type the same IP I used it states I can't connect.
Gold
Re: How do I telnet into my 4404 Controller
Telnet is disabled by default on the controllers. You can enable it under the Management - Telnet/SSH page or with the command "config network telnet enable"
Hall of Fame Super Gold
Telnet, by default, is disabled. Try SSH. If not do what Dan has described and enable Telnet via HTML or HTTPS.
I do not encourage/recommend unsecure access to the WLC via Telnet and/or HTTP.
Hope this helps.
131
