How many Client support AIR-CAP1702I
I want to know How many Clients support the AIR-CAP1702I, just I found a comparative table, but only see 1600 and 2600 series and the 1600 Series support Client count 128 and Clientlink Client count 32.
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#indoorac
Someone may help me?.
Thanks.
1 ACCEPTED SOLUTION
VIP Purple
Hi If you check the 802.11ac
If you check the 802.11ac product tab on the same list you will see it
Note that even these numbers listed, when you plan you should design for 20-30 clients (for normal data use) per radio to get reasonable throughput. If HD video required this number come down further 5-10.
Pls mark this thread "answered" if you get what you looking for.
Rasika
VIP Purple
Rasika
Thanks for the explaining, I
Thanks for the explaining, I Will take that into account.
667
