Community Member
How to assign Password for different SSID in embedded AP - Cisco w1941
Can someone tell me the CLI configuration of the assinging the password for SSID created on embedded AP in cisco 1941.
If so, then can we use WEP encryption on cisco 1941 AP ??
One more thing, I am getting message on SSID icon that "Information sent over this network might be visible to others" what does this mean and how to resolve this problem. Thanks
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: How to assign Password for different SSID in embedded AP - C
Gotcha!!!
The command is..
encryption [vlan vlan-id] key 1-4 size { 40 | 128 } encryption-key [transmit-key]
We need to map the Vlan for each SSID..
So the comand will be..
encryption (vlan vlan#) key 1 size 40bit 7 F3546E765203 transmit-key
We need to make sure that... under the SSID, we have mapped the coresponding vlan..
that is.. if you have a SSID by name XYZ and you want the clients to get the IP from vlan 10.. then the config will be..
en
config t
dot11 ssid XYZ
vlan 10
auth open
mbssid guest-mode
end
config t
int dot11 0
encryption vlan 10 mode wep mandatory
encryption 10 key 1 size 40bit 7 F3546E765203 transmit-key
no shut
end
and followed by the subinterface commands.. and the same should be done for all the other SSIDs with different VLAN mappings and keys.
let me know how this works out for you!!
Surendra
CLI configuration of the assinging the password for SSID created on embedded AP in cisco 1941. If so, then can we use WEP encryption on cisco 1941 AP ??
ANS -
en
config t
int dot11 0 or int dot11 1
encryption vlan mode wep mandatory
encryption key 1 size 128 or 40  (if used 128 bit then password will be 26 bit lenght and if 40 bit then its 10 bit password)
end
wr
the above will solve the first issue..
ANS -
This means that the SSID is getting broadcasted and any one who can scan for wireless signal can connect to it if the credentilas are known.. if you done want to broadcast then the person who connects to wireless should know the SSID to connect.. to make it invisible.. the below commend will do it..
en
config t
no guest-mode
end
wr
This will solve the second question..
Surendra
Community Member
Dear, Thanks for your quick response.
For the first question, let me tell you i did the same it is asking now the password.
We dont need to change any setting on dot11 ssid Guest interface currently there is authentication open command.
dot11 ssid Guest
   vlan 101
   authentication open
   mbssid guest-mode
Secondly, how to configure WAP for SSID in embedded AP - Cisco 1941. Thanks
Community Member
The procedure you told for wep configuration is as below:
ap(config-if)#encryption vlan (vlan#) mode wep mandatory
ap(config-if)#encryption key 1 size 40 0 1234567891
It does ask for password but it doesn't allow to connect.
*Mar  2 19:10:37.101: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 001d.e008.ebb9 Reason: Sending station has left the BSS
if static IP address id asgned to the Laptop.. are we able to ping the Default gateway?
Surendra
configuring ssid--
en
config t
dot11 ssid
end
wr
The abve will configure the SSID
How many SSID are configured?? if more than one.. then we need to map the vlans to respective SSID..
Surendra
Plz let me know your requirements and provide me the how you want your user to connect.. i will help you out..
Surendra
Community Member
i have 4 ssid and i have managed to broadcast them. I have created 4 separate vlans on router. on ap side, 4 interface Dot11Radio0.xxx and 4 interface GigabitEthernet0.xxx. Everything is working and Internet is also working.
Now i have to put different password (WEP) for each ssid. how to put encryption command each ssid. I put the 2 commands you gave me on every vlan number but configuration shows only one time  encryption key 1 size 40bit 7 F3546E765203 transmit-key
Configuration is as below:
encryption vlan 1xx mode wep mandatory
encryption vlan 1xy mode wep mandatory
encryption vlan 1yy mode wep mandatory
encryption vlan 1yz mode wep mandatory
ssid xxx
ssid xxx
ssid xxx
ssid xxx
antenna gain 0
mbssid
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
Gotcha!!!
The command is..
en
config t
dot11 ssid XYZ
vlan 10
auth open
mbssid guest-mode
end
config t
int dot11 0
no shut
end
Surendra
Community Member
I again did the same and now i worked out. Don't know what was missing. Thanks
I have 4 ssid. I need to put 2 encryption by WEP and 2 by WPA.
Can you tell me how to configure WPA for the same. What are the options to configure WPA
Thanks for the ratings!!
If we are using WPA.. then no need to configure WEP encryption... the encryption should be either
1>> CHIPHERS TKIP
or
2>> CIPHERS AES
so the configuration will be..
en
config t
dot11 ssid
auth open
vlan X
auth key-management WPA (version 1 or 2)
end
wr
[you can configure the WPA version by using the question mark after WPA and  select the appropriate, version 1 then use TKIP and if VERSION 2 then  use AES]
en
config t
encryption valn X mode ciphers TKIP (WPA) or encryption valn X mode ciphers AES (WPA-v2)
no shut
end
wr
the above wil do it..
Surendra
WPA is the Authentication... not the encryption... WEP is the encryption not authentication..
Surendra
3250
