how to check ap2702i antenna status
How could I check is ap2702i  working with 4x4 antenna or 3x3 antenna ?
Can I get any informatio from WLC ?
Thanks.
2 ACCEPTED SOLUTIONS
VIP Purple
Hi,As per my knowledge there
As per my knowledge there is no command on WLC to check the status of Antenna on AP.
you will have to physically inspect it.
Dont forget to rate helpful posts
I agree with Sandeep on this
I agree with Sandeep on this.
The only thing you can see on the WLC side is the PoE status of the AP. For example: when you connect a 3700 AP to a 802.3af PoE switchport, you will see status "PoE/Medium Power (15.4 W)". You do have to consult the documentation to discover what radio's or streams are disabled for that particular AP type in that situation.
VIP Purple
531
