How to check channel utilization
vijay kumar
Level 2
Level 2
Hi all,
Please tell me the command to see the AP's chanel utilization?
Scott Fella
Use the WLC config analyzer and input the WLC(s) show run-config and that will show you all the AP's utilization, client count, etc.
https://supportforums.cisco.com/docs/DOC-1373
The show run-config has all this information that the config analyzer can parse. It's a good tool to have if you don't have WCS/NCS or Prime.
-Scott
10 Replies 10
Sandeep Choudhary
HI Vijay,
To display access point channel utilization metrics, use the show 802.11 cu-metrics command.
show 802.11{ a | b} cu-metrics cisco_ap
Hi Sandeep ,
Thanks for the quick response. But It is giving error " CU Metrics : Traffic stream metrics is disabled on this band. Please enable it first" on both bands.
Sandeep Choudhary
Also Take a look:
show advanced 802.11b monitor
show advanced 802.11a monitor
Dont forget to rate helpful posts
Hi Sandeep ,
show advanced 802.11b monitor is not ginving the info on channel util.  I  am able to see the chnnel util by " show ap auto-rf 802.11b AP_name" . But Can I see the utilization for all the AP's in single command?
(WLC) >show ap auto-rf 802.11a
Normally this commands give the channel utilization for specif AP:
regards
Scott Fella
-Scott
Thanks a lot Mr.Scott for the info.
No problem. The command that Sandeep mentioned will also get you information on a specific AP.
-Scott
grep include "Channel Utilization" show ap auto-rf 802.11b "AP name" ==> For 2,4 Ghz
grep include "Channel Utilization" show ap auto-rf 802.11a "AP name" ==> For 5ghz
hoanghoang93
Experts please help me check channel utilization on Autonomous Aironet 3600,3700.
Help me ,i really need it.
