How to check highly utilized APs on WLC?
Hi guys,
On the WLC, is there a way (GUI or cli) where we can pull up highly/highest utilized APs, in terms of no. of association, channel utilization etc. without actually going into each individual AP?
Also, on what scale WLC reports the channel utilization, is it in percentage? I recall I read somewhere it is actually on a scale on 1-255? How to read the utilization correctly?
Utkarsh
VIP Purple
Hi Utkarsh,NO by WLC  its not
Hi Utkarsh,
NO by WLC  its not possible but if you have WCS or NCS then you can check the thresolved level on AP and many other things.
Dont forget to rate helpful posts
Hi Sandeep,Thanks for your
Hi Sandeep,
Thanks for your response.
I thought the same that without WCS or NCS it's not possible. Looks like I have to convince the management to invest in NCS! ;)
Utkarsh
Hall of Fame Super Gold
This will depend on your
This will depend on your firmware.
If you have, for example 7.6.X, if you click the All Details of all the APs, you'll note a column of the number of wireless clients.
Otherwise, if you want more granularity, you'll need to invest on Prime Infrastructure to generate report.
However, if you know a lot of about PERL scripting and SNMP, then you can write up a script to do what you want.
Hi Leo,Thanks for your
Hi Leo,
Thanks for your response. Unfortunately, the WLC is running on 7.4.100.0 and I don't know a LOT of scripting :(
Any pointers about the channel utilization? Is it reported in %age?
Utkarsh
48
