How to choose wireless router
CSCO12447822
I am facing with the problem.How to choose the wireless router part number support the following:
  • Support 802.11n/a/b/g standard
  • Operates on both 2.4 and 5 GHz frequency
  • Support Power over Ethernet (so you don’t have to wire the power cable, just use LAN)
  • Support QoS in order to provide different service level based on priority
  • MUST have WPA2 encryption
Best Regard,
Kthh
7 Replies 7
Charlie Moreton
The 3600 AP has an AC module that suits your needs.  The SKU tha includes the module is:
AIR-3602E-AC-xK9 or
AIR-3602I-AC-xK9
3602E has external antennae while 3602I has internal.  Replace the x in xK9 with the letter for yout regulatory domain.  US would be AK9.
Cisco also has an AP with internal AC capabilities, the 3700.  The SKUs are:
AIR-CAP3702E-x-K9 or
AIR-CAP3702I-x-K9
Please Rate Helpful posts and mark this question as answered if, in fact, this does answer your question.  Otherwise, feel free to post follow-up questions.
Charles Moreton
Thank you for your answer Mr.Charles Moreton.
I confused with the APs suit with my requirement .
I haven't found qos specifications in the datasheet.
so I want to confirm the APs your recommended support QoS.
Best Regards.
this require controller or not.
I want to use as standalone.
Best Regards.
Can I use Cisco 890 Series for my requirement.
If I can , how can i choose Part Number.
Best Regards
Exactly what are you trying to do?
The new 890FW comes with LIMITED country codes.  The WiFi is NOT compatible in some countries due to regulatory domain.
Thank you for your answer,Mr. Leo Laohoo.
Our country is Myanmar,So I choose C891FW-E-K9.
Your answer make me strong to choose this.
Best Regards,
I have a legitimate question and you've rated my last post with a 1-star?
You're on your own.
