01-22-2012 07:07 PM - edited 07-03-2021 09:25 PM
Dear All,
I would like to ask you that how can i configure air-lap1141n-a-k9 ?
Does model air-lap1141n-a-k9 need Wireless controller?
Best Regards,
Rechard
01-22-2012 07:12 PM
You can downgrade the IOS so you will not need a WLC (autonomous IOS).
01-22-2012 07:20 PM
Dear Leolaohoo,
Could you let me know how to upload IOS in to wireless., now i cannot do any thing on wireless...
Best Regards,
Rechard
01-22-2012 07:28 PM
The link above will guide you on how to change the IOS of your WAP from controller-based to autonomous.
01-22-2012 07:57 PM
Dear Scott and Leolaohoo,
if i don't want to change IOS to WLC (autonomous IOS), is it working without wireless controller?
I will rate to you and thank for your help!
Best Regards,
Rechard
01-22-2012 08:01 PM
If you have a lap1142, then you need a wlc. If you don't want a wlc, you will need to convert the ap to ios (autonomous).
Scott Fella
Sent from my iPhone
01-22-2012 07:21 PM
Just to add to Leo's post. The part number will tell you if you need a wlc or if it is IOS. The "LAP" mean lightweight access point and you need a wlc. "AP" is IOS. If you wanted a standalone AP, you should of bought a AP1142N-A-K9.
Like Leo mentioned you can convert it to autonomous
Convert to autonomous
https://support.soundenterprises.net/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=28
Autonomous Guide
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html
Scott Fella
Sent from my iPhone
01-27-2012 01:04 AM
Thanks you for your help!
Best Regards,
Rechard
