how to configure HA with WLC 5760
I want to know how to configure HA with WLC 5760.
The documentation is not very clear :
The "WLC-5760-config-guide" says:
“Before you enable HA (AP SSO), ensure that both controllers are physically connected through the redundant
port using an Ethernet cable. Also, ensure that the uplink is connected to an infrastructure switch and that the
gateway is reachable from both the controllers.”
But I cannot see any redundant port on the appliance !
The "High Availability (AP SSO) Deployment Guide" explains HA for 5500/7500/8500 WLC, but nothing for 5760
And the "5760 deployment guide" explains HA with soft relase 7.3 ,  which is not compatible with 5760. because 5760 requires an IOS-XE .!!!
So I am quite confused !
How does HA work with 5760 ?
Is there only one config for the 2 WLCs, like with 5508 ? Or is it two independant WLCs ?
Thanks in advance for your help.
Michel Misonne
1 ACCEPTED SOLUTION
Re: how to configure HA with WLC 5760
5760 does not support HA AP SSO.
You can do the traditional two controller setup. Where you can have a 1:1 redundancy or split the APs across the two controllers.
Silver
Thanks a lot.
This is more clear now.
HA with 5760 is more a licensing-feature than a technical feature.
HA SSO is now supported in the latest version of code, though you will need a to stack the controller via stackwise cable.
656
