How to configure WPA on Aironet 1300 without using RADIUS
I'm trying to set up a couple of Aironet 1300s. I want to use WPA, but I don't have a radius server.Is it possible to configure then 1300s to use WPA with a password and not a RADIUS server? Thanks.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: How to configure WPA on Aironet 1300 without using RADIUS
Yes this is possible.  Under the Radio you call the encryption method you want to use:
encryption mode ciphers tkip
then under the ssid:
dot11 ssid Test
authenticaiton open
authenticaiton key-managment wpa
wpa-psk ascii 0 cisco1234
So long as the encryptions and keys match on both sides, and one is root bridge and the other nonroot they should bridge just fine
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
dot11 ssid Test
authenticaiton open
That's exactly what I need. Thanks.
1386
