how to default cisco air-lap 1522ag-e-k9
  Please can anyone be kind enough to help me with how to default the above access point (air-lap1522ag-e-k9).I have the recommended power injector.I have followed the instruction on the cisco document but no joy.I have press the reset button which reboot the unit but still I cannot access the console.it boot up with the old password.I have also press the reset button and power on the unit but no joy.
Any quick help will be highly appreciated.
Many thanks.
Kaycee
Hall of Fame Super Silver
Re: how to default cisco air-lap 1522ag-e-k9
What instructions have your tried. Are you able to login with the old password? Have you tried to join it to a WLC and reset it that way?
-Scott
Thanks for your quick response.
The document instrusted me to press the reset button and it will reboot. I have done that but no joy.I do not have  a wlc connected to it. We just acquire it but it has been passworded by the previous owner.I have my console connected to it on my desk and it is powered on by a cisco pwr injector. it boot okey but I am unable to access the console, it rquest for a password which i do not have and the only  way  I think is to default it.
once below is the boot up details
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 12 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 4512256
flashfs[0]: Bytes available: 27356672
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 00:26:51:5f:df:00
Loading "flash:/c1520-k9w9-mx.124-3g.JMC2/c1520-k9w9-mx.124-3g.JMC2"...#########
File "flash:/c1520-k9w9-mx.124-3g.JMC2/c1520-k9w9-mx.124-3g.JMC2" uncompressed a
nd installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1520 Software (C1520-K9W9-M), Version 12.4(3g)JMC2, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 24-Oct-08 12:08 by alnguyen
Image text-base: 0x00003000, data-base: 0x01000000
Initializing flashfs...
flashfs[1]: 12 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31868928
flashfs[1]: Bytes used: 4512256
flashfs[1]: Bytes available: 27356672
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio 1 A600 8000 0 0 A8030000 30
Radio 1 A600 8000 0 0 B8030000 13
Radio 0 0 0 0 0 0 11
Radio 0 0 0 0 0 0 14
%Error opening flash:/c1520-rcvk9w8-mx/info (No such file or directory)cisco AIR
-LAP1522AG-E-K9   (PowerPC 8349) processor (revision A0) with 49142K/16384K byte
s of memory.
Processor board ID FCW1334W02V
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 4.1.192.35
4 Gigabit Ethernet interfaces
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:26:51:5F:DF:00
Part Number                          : 73-10918-04
PCA Assembly Number                  : 800-28909-04
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1329431A
Top Assembly Part Number             : 800-29338-04
Top Assembly Serial Number           : FCW1334W02V
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1522AG-E-K9
Press RETURN to get started!
*Mar  1 00:00:05.919: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar  1 00:00:05.927: *** CRASH_LOG = yes
*Mar  1 00:00:06.255: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:06.755: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar  1 00:00:07.251: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 1
*Mar  1 00:00:08.387: %LINK-3-UPDOWN: Interface GigabitEthernet4, changed state
to up
*Mar  1 00:00:08.387: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:08.387: %LINK-3-UPDOWN: Interface GigabitEthernet1, changed state
to up
*Mar  1 00:00:08.387: %LINK-3-UPDOWN: Interface GigabitEthernet2, changed state
to up
*Mar  1 00:00:08.387: %LINK-3-UPDOWN: Interface GigabitEthernet3, changed state
to up
*Mar  1 00:00:08.411: %SYS-5-RESTART: System restarted --
SOFTWARE (fc1)
*Mar  1 00:00:08.415: %SNMP-5-COLDSTART: SNMP agent on host APMesh_Pos_11 is und
ergoing a cold start
*Mar  1 00:00:08.475: %MESH-6-BVI_CREATED: Mesh BVI1 interface created
*Mar  1 00:00:08.479: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:00:08.479: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:09.387: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet0, changed state to down
ernet1, changed state to down
ernet2, changed state to down
ernet3, changed state to down
*Mar  1 00:00:09.479: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:10.063: %CDP_PD-2-POWER_LOW: All radios disabled - INJECTOR_DETECT
ED  (0000.0000.0000)
*Mar  1 00:00:10.475: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:13.667: %DOT11-6-FREQ_USED: Interface Dot11Radio1, frequency 5540
selected
*Mar  1 00:00:13.671: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:13.671: %DOT11-6-FREQ_SCAN: Interface Dot11Radio0, Scanning freque
ncies for 22 seconds
*Mar  1 00:00:14.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:17.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet4, changed state to up
*Mar  1 00:00:19.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEth
ernet2, changed state to up
*Mar  1 00:00:27.479: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:31.287: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency st
ate machine started
*Mar  1 00:00:31.287: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:31.291: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:00:32.291: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:33.287: %MESH-6-LWAPP_RESTART: Mesh Lwapp re-started
*Mar  1 00:00:33.287: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:33.291: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Mar  1 00:00:34.891: %DOT11-6-FREQ_USED: Interface Dot11Radio1, frequency 5660
selected
*Mar  1 00:00:34.895: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:35.287: %LINK-3-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:00:35.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:36.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:00:36.899: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:36.903: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:37.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
APMesh_Pos_11>
when you enter enable at the console it request for a password.
Yes pls. I have Cisco but it did not work. once again thanks for your quick rsponse.I appreciate.
Thanks a million.
Kaycee
Well have it join the WLC and then reset it. You can also change the password for the unit from the WLC. I have not had an issue resetting mesh AP's using the button.
-Scott
Have you tried Cisco
-Scott
Alright Scott Fella, thanks for your time.I do not have a wlc available to me now,I am only testing it to be sure it is ok before it will be sent to the field for full installation.
Many thanks Bro.
Kaycee.
I don't send any mesh AP's on the field until I have staged them and make sure they do come up.
-Scott
definately, I only wanted to just do a limited test on it.
Kaycee
To reset the  1522 AP you could attempt to reset the AP
using the reset button. The reset button is located horizontally to the
left of the 4 LED's and is recessed in a small hole, sealed with a screw
& a rubber gasket. To reset the AP press the Reset Button for less than
10 seconds, LEDs should turn off for 5 seconds and reactivate.
The reset button on the unit does NOT do a reset back to factory
defaults.  Depressing the reset button  until the LEDs turn on does a
general reset, but NOT a full reset to factory.
If you can console into the AP, you should be able to issue the
following commands and reload to reset it factory defaults:
debug lwapp console cli (OR debug capwap console cli if on 5.2 or later)
erase /all nvram:
reload  (disconnect the Ethernet until the device boots up)
Please find the information in the link below:
http://www.cisco.com/en/US/docs/wireless/technology/mesh/design/guide/Me
shAP_60.html#wp1294976
Thanks a million for your time and respons.I am on the  user exec mode only where it request for a password when you enter enable.I am stock there.
you are absolutely right when you I press the reset button,it only reboot but not factory defaulted.I am unable to gain access into the privilege mode where I can issue the above command you recommended.
I appreciate your response,I will follow the link that you sent now.
thanks.
Kaycee
928
