how to join an Ironet 3602E with a Catalyst 3850
Hi everyone
Can anyone guide me with this configuration.
I have one Ironet 3602E and a Catalyst 3850, I want to configure the WLC module of the Switch in order to join it with my AP.
The AP is in Lightweight mode, with the latest version. the Catalyst is using the 03.02.02.SE RELEASE SOFTWARE (fc2)
According to the configuration guide, I don´t need to much configuration to join my AP with the Catalyst, what I did was configure the VLAN 1 ip add (10.0.0.1/24), a DHCP scope, all ports on VLAN1, one SSID on VLAN1.
But when I connect the AP on any port of the switch it keeps getting this messages
AP6c41.6a29.7d2b#
AP6c41.6a29.7d2b#
AP6c41.6a29.7d2b#
AP6c41.6a29.7d2b#
Not in Bound state.
*Mar  1 00:04:08.123: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:04:18.127: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:04:18.235: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.0.0.13, mask 255.255.255.0, hostname AP6c41.6a29.7d2b
Translating "CISCO-CAPWAP-CONTROLLER.demo.com"...domain server (8.8.8.8)
*Mar  1 00:04:28.123: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:04:46.123: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.demo.com
Not in Bound state.
*Mar  1 00:05:21.623: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:05:31.627: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:05:31.735: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.0.0.14, mask 255.255.255.0, hostname AP6c41.6a29.7d2b
*Mar  1 00:05:41.623: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:05:59.623: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.demo.com
Not in Bound state.
*Mar  1 00:06:35.123: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Writing out the event log to flash:/event.log ...
*Mar  1 00:06:45.151: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: Could not discover WLC using DHCP IP address, Reload to use static IP.
*Mar  1 00:06:45.151: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Macronix Mirrorbit (00C2)
Xmodem file system is available.
and then it reboot by itself.
do you know if I´m missing something?
Hope you can help me with this
Best Regards
Alvaro Rugama
Everyone's tags (8)
1 ACCEPTED SOLUTION
VIP Purple
You should see below two lines in your configuration. First line say it is acting as Mobility Controller (MC). Also make sure your switch has IPbase or IPservices image.
wireless mobility controller
wireless management interface Vlan1
See the below post for detail.
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Rasika
*** Pls rate all useful responses ****
Hall of Fame Super Gold
AP is not getting an IP address.
Hi Leo Laohoo
I think it is getting IP address
Not in Bound state.
it saids it is getting the 10.0.0.13, but can not discover the WLC.... why it is not discovering it???
that's my problem.
The AP is directly connected into the switch. there is no more connections beside this one. the WLC (Catalyst 3850) hasta the DHCP configuration, so, I don´t need an external DHCP server.
How do I know that the WLC module is enable on the Catalyst??? I activate the 90 ap evaluation license.
Best Regards
VIP Purple
Rasika
thanks you so much raskanayanajith
That article help me a lot.
I clear all the configuration and did what the article explained. So helpful
Best Regards
Alvaro Rugama
VIP Purple
Hi Alvaro,
Glad to see that help & you were able to get this working.
Thanks for rating as well
Rasika
351
