07-19-2013 12:04 PM - edited 07-04-2021 12:28 AM
We have 2504 Controller with 24 AP's registered in a hotel and we would like to limit bandwidth per connection or per user.
I went to QOS Profiles > Bronze >
I do not see Per user Bandwidth Contracts(K)* instead I see WLAN QOS Parameters with below options.
07-21-2013 01:45 AM
You should have bought meraki instead, they have that support.
Otherwise you need a firewall to do per IP traffic shaping. Just doing ordinary QoS won't help you.
Cisco needs to grab Meraki client limitations asap. Or you can buy that 5760? IOS controller built into the 3850 switch.
If I remember correctly, that one can shape traffic basednon clients
11-06-2014 09:55 AM
Has anyone solved this? I have a 2504 running 7.5.102.0 and I do not see the ability to limit a QOS profile to a data rate. The config guide says you can but in QOS profiles but all I see there is the same view as the original post that started the thread. also, if I go to a WLAN and look at the QOS tab there is nothing there to allow you to rate-limit.
Jim
03-06-2015 12:06 PM
As stated in the document below, code version 8.0 introduced some AVC enhancements, among others, per client rate limiting on WLAN.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80.html#pgfId-1187087
Can anyone confirm that this works on 2504 too?
Thank you,
Sebastian
03-07-2015 07:55 AM
In the meanwhile I upgraded a 2504 WLC to code 8.0.110. For those who are interested, there is still no "Per-user Bandwidth Contracts" like on the 5508.
Regarding the AVC profiles, there is a new feature which was not included in the previous software versions. Rate limiting for applications is possible now. Before code 8.0 there were only two action types: drop or mark.
I hope this helps others too,
Sebastian
07-21-2013 02:47 AM
The 2504 doesn't support bandwidth contracts like the 5508's and WiSM's.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
11-07-2014 12:48 AM
Hello
Our WLC model 5508, but there is confusion on difference between Override Per-User Bandwidth Contracts (kbps) vs Override Per-SSID Bandwidth Contracts (kbps)
Our requirement-
hope to get some response
cheers
ST
07-21-2013 07:27 PM
Go the Bronze QoS profile on your controller and enter in values similar to this: note this would throttle the average data rate to 250k
- Average Data Rate: 250kbps
- Burst Data Rate: 500kbps
- Average Real-Time Rate: 250kbps
- Burst Real-Time Rate: 500kbps
Hope this helps
08-23-2013 06:39 AM
On our 2504, we currently have software version 7.2.115.2. Our screens look like those of Nova Support above.
It is our understanding that the features in version 7.4 will give us the options you mention in the Bronze QoS profile. We are covered by SmartNet, and will be performing this update in the next few weeks.
Thanks all for the input.
03-25-2015 09:07 AM
Hi there,
just to confirm, when this configuration is implemented, where is the limitation enforced: on the WLC or on the AP?
Thanks in advance
Gustavo
04-13-2017 06:17 AM
Hello!
On 2504 cou can only configure QoS Roles for Guest Users and assign this Role to configured Users.
