02-27-2003 09:46 AM - edited 07-04-2021 08:32 AM
All our bridges and access points and clients use the same open authentication with static WEP key. Short of deploying a custom configuration for my bridge connections, is there a way to prevent clients other than bridges in client role from associating with my root bridge?
02-28-2003 09:38 AM
You can configure MAC address filtering to allow associations from AP's and Bridges. Deny everything else which will in turn deny association from all the wireless clients.
Here is the url for that.
Follow step 1 to step 8.
02-28-2003 01:45 PM
How about AP's with lower signal strength in the same vicinity as the root bridge... if a client finds two signals (a strong one from the bridge and a weaker one from a nearby access point) and gets rejected from associating with the "good" signal due to MAC address filtering, will the client still try to associate with the weaker signal afterwards? Thanks for the link to the document; very helpful.
