How to program Aironet 1200 for 3 VLANs
Hello. I'll admit to being a Cisco IOS newbie up-front.
I work in a small private high school. We had two dozen Aironet 1200 access points and a controller donated to us from a local hospital that no longer needed them. My boss would like me to set one up with 3 VLANs:
- encrypted VLAN for staff
- encrypted VLAN for students
- unencrypted VLAN for guests
Ultimately, we'd like the staff VLAN to have access to all internal network resources, the student VLAN to have access to several pre-defined printers, and the guest VLAN is web-only access. Whether the controller we were given will accommodate that, we won't know until we get one Aironet 1200 programmed and connected to the controller. For the time being, I just want to get this access point programmed with the 3 VLANs.
I'm easily able to get it running a single SSID (non-VLAN) network and confirm that I can use that network fine. However, I need to set up these 3 VLANs and am hoping someone can walk me through programming it. I can connect to it via telnet if that'll let me program it faster.
Any suggestions? help?
1 ACCEPTED SOLUTION
Re: How to program Aironet 1200 for 3 VLANs
Hello David
I would be more than glad to contribute to this.
Lets assume the following scenario , you have three ssids:
ssid1 : staff --> vlan1 wpa-psk
ssid 2:students -->vlan2 wep
ssid3:guests-->vlan3 open authentication
Assuming vlan 1 :192.168.1.0/24
                vlan 2:192.168.2.0/24
                vlan 3:192.168.3.0/24
L3 Switch ----- AP
AP(config)#dot11 ssid staff
               # vlan 1
               #authentication open
              #authentication key-management wpa
              #exit
AP(config)#dot11 ssid students
              #vlan 2
              #exit
AP(config)#dot11 ssid guests
               #vlan 3
              #guest-mode
              #exit
AP(config)#interface dot11radio 0
               # encryption vlan 1 mode ciphers tkip
               #encryption vlan 2 mode wep mandatory
               # encryption vlan 2 key 1 size 128bit .......
               #ssid staff
               #ssid students
               # ssid guests
               #no shut
               #exit
* Assuming vlan 1 is the trunk native vlan *
AP(config)#interface d0.1
              #encapsulation dot1q 1 native
              #bridge-group 1
             #exit
AP(config)#interface d0.2
               #encapsulation dot1q 2
              #bridge-group 2
             #exit
AP(config)#interface d0.3
               #encapsulation dot1q 3
              #bridge-group 3
             #exit
AP(config)#interface fa0.1
              #bridge-group 1
             #exit
AP(config)#interface fa0.2
              #bridge-group 2
             #exit
AP(config)#interface fa0.3
              #bridge-group 3
             #exit
AP(config)#interface bvi1
               #ip add 192.168.1.2 255.255.255.0
               # no shut
On the Switch:
SW(config)# vlan 1
                 #vlan 2
                 # vlan 3
SW(config)# interface vlan 1
                # ip add 192.168.1.1 255.255.255.0
                # no shut
               #exit
SW(config)# interface vlan 2
                # ip add 192.168.2.1 255.255.255.0
                # no shut
               #exit
SW(config)# interface vlan 3
                # ip add 192.168.3.1 255.255.255.0
                # no shut
               #exit
* Now configure the switch port connecting the AP as dot1q trunk with native vlan being 1*
SW(config-if)#switchport trunk encapsulation dot1q
                   # switchport trunk native vlan 1
                   #switchport mode trunk
                   # exit
Make sure that you define DHCP pools for clients in the various vlans which i assume you already have it.
I hope this has been informative to you.
Please make sure to rate correct answers
Hall of Fame Super Silver
David,
What model/part # is your AP and wlc? We need this information first to see if the ap and wlc are compatible.
-Scott
Scott,
The Aironet 1200 is model AIR-AP1231G-A-K9. The controller is the Cisco 1130 Wireless LAN Solution Engine.
-- David
Well the 1130 is an old platform (WLSE) and you probably will not ever use that.  You will have to manually configure each access point to do what you want it to do.  Here is a guide on configureing multiple ssids:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37ssid.html
-Scott
Wow, I had a feeling that this project was going to be problematic. I'm going to look at the info/link you shared and will try to program the Aironet 1200 on my desk. I'll let you know tomorrow how it goes.
Thanks.
Hello David
L3 Switch ----- AP
               # vlan 1
              #exit
              #vlan 2
              #exit
               #vlan 3
              #guest-mode
              #exit
               #ssid staff
               #ssid students
               # ssid guests
               #no shut
               #exit
              #bridge-group 1
             #exit
              #bridge-group 2
             #exit
              #bridge-group 3
             #exit
              #bridge-group 1
             #exit
              #bridge-group 2
             #exit
              #bridge-group 3
             #exit
               # no shut
On the Switch:
SW(config)# vlan 1
                 #vlan 2
                 # vlan 3
                # no shut
               #exit
                # no shut
               #exit
                # no shut
               #exit
                   # exit
Thanks maldehne, these are the commands I finally used for testing purposes, based on your suggestion:
enable
configure terminal
interface dot11radio0
ssid chs-staff
vlan 1
authentication open
encryption vlan 1 mode wep mandatory
encryption vlan 1 key 1 size 128 11111111111111111111111111 transmit-key
exit
interface dot11radio0.1
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
exit
interface fastEthernet0.1
no ip route-cache
bridge-group 1
exit
ssid chs-students
vlan 2
authentication open
encryption vlan 2 key 1 size 128 22222222222222222222222222 transmit-key
exit
interface dot11radio0.2
no ip route-cache
bridge-group 2
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
exit
interface fastEthernet0.2
no ip route-cache
bridge-group 2
exit
ssid chs-guests
vlan 3
authentication open
guest-mode
exit
interface dot11radio0.3
no ip route-cache
bridge-group 3
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
exit
interface fastEthernet0.3
no ip route-cache
bridge-group 3
exit
station role root
preamble-short
dot11 extension aironet
no shutdown
end
copy running-config startup-config
I'm able to connect on all three networks. Now, we'll set up the DHCP pools, configure the switch for the 3 VLANs, and add rules to the firewall to specify what resources can/cannot be accessed depending on role.
Thanks everyone!
Great
1624
