08-14-2013 12:04 PM - edited 07-04-2021 12:39 AM
WLC 2504 running software version 7.4.100.0.
Goal:
We currently have the wifi-network running and is servicing web access only.
Any ideas on how best to go about this? There will be need to assign two different IPs to wireless clients depending on which WLAN they access.
Thanks.
08-14-2013 12:46 PM
Hello Daniel,
So in order to segregate traffic based on the WLAN they are connecting to, you will first need to establish/create dynamic interfaces on your controller which will be 'mapped' to a specific SSID(ie. Private or Guest):
If you already have the dynamic interfaces in place, you simply just create the WLAN under WLANs > Create New > Go. Once you apply, you will be sent to the 'General' section where you can apply the 'Interface' to the dynamic interface you created in which to put the client on.
Cheers,
Erwin
______________________________________
How helpful was I? Don't forget to rate me when you have the chance!
08-14-2013 12:51 PM
If you want to drive guest to a DMZ and I dont know the size of your network most folks use an anchor to do this. Or you can truck this to a DMZ.
Here is an example without an anchor
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008070ba8f.shtml
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
08-14-2013 12:53 PM
Here is an anchor example
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob30dg/GstSvc1.html
08-14-2013 12:55 PM
Thanks George for your feedback as well. Allow me to review. I appreciate it.
08-14-2013 12:53 PM
Thanks Erwin for the speedy response. Let me take a closer look at what you're suggesting and will feedback shortly.
08-14-2013 02:40 PM
Let me add my 2 cents.
You can purchase another 2504 since they support guest anchoring as the example George posted. You need v7.4 or later which you already have. Or you can specify ports on the 2504 and connect one port to your inside network and one in your dmz like the Erwin mentioned, but you specify the dynamic interface to a certain port in the wlc.
08-15-2013 06:41 AM
Scott, thank you also for the response. Allow me to all digest the recommendations. Again, I appreciate each response.
08-15-2013 08:26 AM
If you can afford a second controller, I would do this and make it a Guest Anchor as mentioned above. This way the traffic is encrypted all the way to the Guest anchor controller (which sits in your DMZ) and is then switched onto the Internet.
If not, the 2504 has seperate physical interfaces so you could have one which goes into your LAN and another which goes into your DMZ switch. Setup seperate virtual interfaces on the controller and ensure the traffic goes seperately across the physical links, once onto the LAN and the other into the DMZ and onto the web.
