How to start troubleshooting wireless users
I know this is a vauge question, but what are some of the things in the WLC GUI that I would start looking at in the event of users complaining that they "can't connect to the SSID"?
Assuming that the password, hardware, end-user, etc is correct.
I'm new to the WLC, so I just wanted to kind of get an idea on what are some of the normal steps to follow when attempting to troubleshoot why a user can't connect or what's causing the non-connection issue.
Everyone's tags (4)
Re: How to start troubleshooting wireless users
You would look at the message log.
But better would be to do a debug client < client Mac address > from the CLI.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thank you, that is defiently helpful.
After talking to some people, I have come to the conclusion that if a user cannot establish a connection to a SSID - there is really no troubleshooting options available (aside from debugging the client).  Would this be a true statement?
Depends on what isues you are having.  you could also sniff the air with something like Omnipeek or other program.  But debugging on the WLC is definetly easier.
HTH,
Steve
Ken,
One of the easy first steps you can do is look at the client in the WLC GUI and see what state it is in. Click on CLIENTS and then click on the client MAC that is having problems. Then look on the left hand side for Policy Manager State.
This is the 'state' the client is in. Most times you will see the following:
START -- Meaning the client is starting the process to get on the network
802.1x_REQ - Means the client is failing authentication
DHCP_REQ - Means the client is having a IP issue
RUN - Means lift is good
I would start there ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Thank you both for your time.  This is exactly the path I was looking to get to.
I attached the different "states" a client might show and the "flow"..
375
