HWIC-3G-GSM on ISR 2811 Troubleshooting
Documentation says this 3G card is working in 2800 routers. Why cannot my 2811 not recognize the card?
------------show diag
WIC Slot 0:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-28846-01
        Board Revision           : J0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC134119FD
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Fab Part Number          : 28-7666-03
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : HWIC-3G-GSM
        Version Identifier       : V01
        CLEI Code                : COUIAKTCAA
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 05 1E 41 01 00 C0 46 03 20 00 70 AE 01
          0x10: 42 4A 30 88 00 00 00 00 02 03 C1 8B 46 4F 43 31
          0x20: 33 34 31 31 39 46 44 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 1D F2 03 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 CB 8B 48 57 49 43 2D
          0x50: 33 47 2D 47 53 4D 89 56 30 31 20 D9 02 40 C1 C6
          0x60: 8A 43 4F 55 49 41 4B 54 43 41 41 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
The IOS is c2800nm-advipservicesk9-mz.124-9.T6.bin.
Any ideas are appreciated.
Thanks.
Larry
Everyone's tags (4)
1 ACCEPTED SOLUTION
Larry,
     According to the below link, you need to be runing 12.4(15)T or later for the router to recognize the HWIC.  So upgrade to at least 12.4(15)T and see if it gets recognized.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/prod_qas0900aecd806e0563.pdf
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Did you try using WIC slot 1 or 2?
Joe
Hi Joe,
I have tried all 4 slots.
Thanks.
Larry
Larry,
Steve
Thanks.
1264
