HWIC AP and HWIC 4ESW Bridging ?? Problem
I wonder if anyone can help - I'm trying to setup both a HWIC-4ESW Switch and a HWIC-AP Access Point to work together in the same 1841 router chassis.
What I want to achieve is that clients on both the wired and wireless interfaces are on the same subnet and LAN and can therefore communicate together. At the moment I can only get one or the other to work (Internet Connectivity is fine):
interface Dot11Radio0/0/0
no ip address
ip virtual-reassembly
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid aspremont
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 ***************
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
no cdp enable
end
interface Vlan1
ip nat inside
end
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool DHCP_ADDRESS_POOL
network 192.168.1.0 255.255.255.0
dns-server ********* ************
default-router 192.168.1.1
Unfortunately the IOS version I'm using: 12.4(11)T has some bugs with SDM, so I can see the config in the GUI but not modify it (I don't have access to later version).
I've tried bridging to another interface, adding a vlan to the ssid and a few other things, to no avail.
It must be possible though, as this basically what Home Wireless Routers are doing.
Any help is appreciated.
1 REPLY
Re: HWIC AP and HWIC 4ESW Bridging ?? Problem
No replies but the fix was fairly simple (after a few hours of fiddling).
Create a bridged virtual interface, place both interfaces in the bridge group of this interface, then treat this interface as a normal internal interface (as the inside NAT i/f for example.
A lot of the bridge commands are added automatically after placing the interface in a bridge group:
A Bridged interfaced and bridge irb:
dns-server *********** ***********
bridge irb
no ip address
ssid aspremont
authentication open
guest-mode
wpa-psk ascii 7 *******************
channel 2437
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip nat inside
bridge 1 route ip
306
