I can't use WLAN to reach AP via WEB:(
I have cisco aironet 1200 running ios version 12.2(8)JA.
From a default factory setting, I cannot use the WLAN to reach the managment interface(BVI) via IE.
(1) I can telnet to the interface via the WLAN, but not via teh web.
(2) I can reach the management interface via the web if I connect via a ethernet cable.
What am I doing wrong??????
Re: I can't use WLAN to reach AP via WEB:(
I had the same problem. First, you need to completely remove the AP from the WLSE. Then, you need to rediscover it. Don't try running inventory because it won't work.
Hope it helps.
Thank you
132
