I have a AIR-WLC2112-K9 is not opening in GUI
takyon.networks
when i reset the device it is open in by default ip in GUI but when i configure the device after that when i enter save and reboot command it is not open with new ip in gui.
Justin Kurynny
Level 4
Level 4
Raj,
On which WLC interface are you assigning it a new IP? Make sure you are changing the management interface (and not ap-manager).
Try closing and reopening your browser or using a different browser than the one you used to make the change, or even trying from another computer altogether.
Try http://. There have been a rare number of times that I've seen the secure web (https) somehow get disabled on the WLC and only http works until I re-enable https.
Managing the WLC while connected to it as a wireless client will fail unless you disable management-over-wireless blocking on the WLC. Make sure you are doing your WLC setup over a wired connection.
Justin
Dear,
I have configured like this by command prompt....
Management Interface IP - 192.168.1.2,Subnet - 255.255.255.0, Gateway -
192.168.1.1, Port - 1,Vlan - 0 (untagged)
AP Manager IP Address - 192.168.1.3, Subnet - 255.255.255.0, Gateway -
192.168.1.1, Port - 2,Vlan - 0 (untagged)
When i reset the controller,after reboot first time it is open with this ip
192.168.1.1 but when i configure the device with uuper given detail and
enter save and reboot option after reboot it is not open by 192.168.1.2
ip.i connect my laptop to port 1 of controller to access controller.
RAJKUMAR
+91-8874555503
On Fri, Feb 24, 2012 at 1:35 PM, airframes <
Scott Fella
Raj,
If you are trying to access the WLC, either configure the Service Port and connect directly to that so you can access the GUI or connect port 1 of the WLC to a trunk port and then connect your laptop or pc to a switchport on the same vlan as the wlc management interface. You shouldn't connect your device directly to the wlc. Hopefully I'm understanding your issue here.
-Scott
