Increasing Total Output Drops number
I have an autonomous Cisco AP1242 running on channel 11 (best channel avail) with only one client associated.
Signal Strength and Channel Utilization look good.
By design this client is constantly sending UDP/Multicast packets, so I had to disable IGMP Snooping on the AP. However, I have noticed data dropout and have been able to correlate it by running the command:
show interface dot11radio 0
Every-time I run the above command the Total Output Drops increases:
Dot11Radio0 is up, line protocol is up
  Hardware is 802.11G Radio, address is 001c.b0eb.eb70 (bia 001c.b0eb.eb70)
  MTU 1500 bytes, BW 54000 Kbit, DLY 1000 usec,
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:37:46
  Input queue: 0/1127/0/0 (size/max/drops/flushes); Total output drops: 3178
  Queueing strategy: fifo
  Output queue: 0/30 (size/max)
  5 minute input rate 43000 bits/sec, 14 packets/sec
  5 minute output rate 92000 bits/sec, 17 packets/sec
     29799 packets input, 12551639 bytes, 0 no buffer
     Received 17376 broadcasts, 0 runts, 0 giants, 0 throttles
     41308 packets output, 25121942 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
I cleared the statistics and ran the command after a few minutes.
Any ideas what could be causing packets to be dropped?
QOS is disabled on the AP.
VIP Purple
Re: Increasing Total Output Drops number
What type of volume you are talking about here, what is the data rate (bps & pps) of these multicast traffic flow takes ?. Keep in mind these radio may not have enough buffers to keep these (if you are sending high volume) & output packet drop is expected.
Rasika
**** Pls rate all useful responses ****
There is only one wireless client.
Just took a 5 min Wireshark reading and it giving the following:
Packets: 2286
Avg. packets/sec: 7.729
Avg packet size: 671.527 bytes
Avg bytes/sec: 5190.457
I am new to this. Is the above considered high volume for one client?
I just compared a wired vs wireless captures... I am only losing packets on the wireless medium.
When you say that the radio may not have enough buffer... are you reffering to wireless adapater or the Acess Point?
273
