Inquiry - Cisco Captive Portal without WLC
based on article http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
Is it possible or how should I design captive portal without WLC.
In our organization, I have about 20 AP (various models) running on standalone with VLAN and ACS server for MAC authentication.
I have plan to create new VLAN just only for guest users to browse with username/password URL redirectiotion (without MAC authentication).
Seek your help.
Thank You
Everyone's tags (2)
1 REPLY
Re: Inquiry - Cisco Captive Portal without WLC
Without a wlc you would need another solution to handle the portal piece.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
252
