Community Member
Installation of 1310's
I hope this is in the right area, so here it goes.
I am trying to layout an access point install consisting of Aironet 1310's. It is for a warehouse location and it is at 0 degrees all the time so it was a good choice considering there broad temperature range. However I am not sure how exactly to lay them out to get good coverage. I have thought about mouting at the end of an aisle and then running a cable (for the second antenna) to the other end of the aisle. The other thought would be to mount one every other aisle and run a cable over to the next aisle and get coverage that way. I guess my questions are, which will provide me the best coverage without having to run large amounts of cable?
1 REPLY
Anonymous
N/A
Re: Installation of 1310's
To answer your question you will have to provide much more information on the area where you plan to deploy the Wireless network. I would suggest that you perform a site survey for best results. There are lot of firms which specialise in site survey. A good site survey will help you determine the correct placement locations for your wireless devices and also ensure complete coverage.
164
