11-28-2013 06:40 AM - edited 07-04-2021 01:20 AM
Is it possible to install a widcard certificate for web auth in those versions?
Is there any difference between this two versions.
Are both of them versions supporting wildcards certificates?
Here you have the log file resulting of installing the wildcart certificate in the wlc with v 7.0.240.
*TransferTask: Nov 28 11:20:51.117: Memory overcommit policy changed from 0 to 1
*TransferTask: Nov 28 11:20:51.319: Delete ramdisk for ap bunble
*TransferTask: Nov 28 11:20:51.432: RESULT_STRING: TFTP Webauth cert transfer starting.
*TransferTask: Nov 28 11:20:51.432: RESULT_CODE:1
*TransferTask: Nov 28 11:20:55.434: Locking tftp semaphore, pHost=10.16.50.63 pFilename=/wild2013_priv.pem
*TransferTask: Nov 28 11:20:55.516: Semaphore locked, now unlocking, pHost=10.16.50.63 pFilename=/wild2013_priv.pem
*TransferTask: Nov 28 11:20:55.516: Semaphore successfully unlocked, pHost=10.16.50.63 pFilename=/wild2013_priv.pem
*TransferTask: Nov 28 11:20:55.517: TFTP: Binding to local=0.0.0.0 remote=10.16.50.63
*TransferTask: Nov 28 11:20:55.588: TFP End: 1666 bytes transferred (0 retransmitted packets)
*TransferTask: Nov 28 11:20:55.589: tftp rc=0, pHost=10.16.50.63 pFilename=/wild2013_priv.pem
pLocalFilename=cert.p12
*TransferTask: Nov 28 11:20:55.589: RESULT_STRING: TFTP receive complete... Installing Certificate.
*TransferTask: Nov 28 11:20:55.589: RESULT_CODE:13
*TransferTask: Nov 28 11:20:59.590: Adding cert (5 bytes) with certificate key password.
*TransferTask: Nov 28 11:20:59.590: RESULT_STRING: Error installing certificate.
*TransferTask: Nov 28 11:20:59.591: RESULT_CODE:12
*TransferTask: Nov 28 11:20:59.591: ummounting: <umount /mnt/download/ >/dev/null 2>&1> cwd = /mnt/application
*TransferTask: Nov 28 11:20:59.624: finished umounting
*TransferTask: Nov 28 11:20:59.903: Create ramdisk for ap bunble
*TransferTask: Nov 28 11:20:59.904: start to create c1240 primary image
*TransferTask: Nov 28 11:21:01.322: start to create c1240 backup image
*TransferTask: Nov 28 11:21:02.750: Success to create the c1240 image
*TransferTask: Nov 28 11:21:02.933: Memory overcommit policy restored from 1 to 0
(Cisco Controller) >
Would I have the same results in wlc with v 7.5.102?
Thank you.
Solved! Go to Solution.
11-30-2013 02:42 AM
Hi Pdero,
Please check out these docs:
https://supportforums.cisco.com/thread/2052662
http://netboyers.wordpress.com/2012/03/06/wildcard-certs-for-wlc/
https://supportforums.cisco.com/thread/2067781
https://supportforums.cisco.com/thread/2024363
Dont forget to rate helpful posts.
11-30-2013 02:42 AM
Hi Pdero,
12-05-2013 06:28 AM
HI,
I did the procedure from scratch and it dit work
Problem was the order of the certificate and the codification they had.
Thank you very much.
12-05-2013 06:30 AM
Hi Pedro ,
Glad that u resolved ur problem and thanks for providing ur solution . Can u mark this question as answered , it may help others .
