intermittent connecting to AIR-LAP1242AG-A-K9
                   Hi all,
   Got users who complain about their wifi scanners (Motorola MC9100) out of range even though they are approx 20 - 30 feet to the ceiling-mounted AP units. Any advice please ?
VIP Purple
Hi Duc
Check the power level of 802.11b/g & 802.11a band of this AP via WLC. Also check which band this device get assoicated (if it is 5GHz anyway cell size is small). It may operate in low power depend on the RRM calculations.
If it is operating very low power level (5,6 ,7,8) you can change manually & see if that make any difference (usually you should let WLC to decide power level though )
Rasika
**** Pls rate all useful responses ****
What security you use on the WLAN?
were those devices working fine before with same AP model?
have you made any recent changes just befor the problem to appear?
Do you have any other WLANs close to yours?
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Duc,
This is the list of suggestions that was found to improve interoperability of handheld devices in a controller based environment:
  1. If you are in an environment where older switches are used, the access points (APs) will join the WLC but will not have enough power. Therefore, the radios will not come up. A power injector needs to be used to provide sufficient power.
    config ap power injector enable
  2. Make sure you are running WLC version 4.1.185.0 or later.
  3. Symbol devices running earlier firmware version might not roam properly. It sticks to the AP originally associated. This is a known issue and Symbol has released a Beta Version to fix this. Download the Beta Version from Symbol.
  4. Aironet IE—Aironet IE is a Cisco proprietary attribute used by Cisco devices for better connectivity. Disable Aironet IE. From the WLC GUI go to the WLANs tab. Click on the WLAN to which the symbol devices connects. Go to the Advanced tab and uncheck Aironet IE.
  5. Check if the device is CCX certified to ensure interoperability with Cisco WLCs. Certain symbol devices, such as MC75 and MC5590 (under MPA 1.5 platform), are CCXv4 certified.
    Devices such as MC9090 WM 6.1, MC9090 - VGA WM 6.1, MC9094 WM 6.1, MC7090 WM 6.1, MC7095 WM 6.1, MC7090 WM 6.1, MC7095 WM 6.1, MC70x4 WM 6.1, MC7598 WM 6.1, MC3090 CE5 Pro, MC3090 CE5 Core, WT4090 CE 5.0(MPA 1.0), and VC5090 CE5.0(MPA 1.0) are CCXv3 certified.
  6. Modify the DTIM interval. Good performance has been seen with the DTIM setting of 6.
  7. Client Exclusion per WLAN—This option is normally used to exclude certain clients from accessing the WLAN. Disable client exclusion to make sure that Symbol device is not in the excluded list.
    MFP
    —Management Frame Protection is a Cisco properietary feature introduced to ensure the integrity of the management frames, such as de-authentication, disassociation, beacons, and probes wherein the AP protects the management frames that it transmits when it adds a Message Integrity Check Information Element (MIC IE) to each frame. Any attempt made by the intruders to copy, alter, or replay the frame invalidates the MIC, which causes any receiving AP that is configured to detect MFP frames, to report the discrepancy.
    Disable
    MFP on the WLC.
  8. Load balancing—This feature is used to prevent too many clients from associating to the WLC. Disable this feature to ensure that the device is not rejected by any chance. Click on the Controller tab. Navigate to the General menu to disable Aggressive Load Balancing.
  9. Radio Preambles—The radio preamble (sometimes called a header) is a section of data at the head of a packet that contains information that the wireless device and client devices need to send and receive packets. Long Preamble increases interoperability between the WLC and the client. Click on the Wireless tab.
    Navigate to 802.11 b/g/n and click the Network option, then uncheck Short Preamble.
  10. Disable the Client Exclusion Policies Globally. Click on the Security tab and navigate to Client Exclusion Policies under the Wireless Protection Policies menu.
    Uncheck the options under Client Exclusion Policies.
Please refer the link:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/110363-symbol-devices-cue.html
Thanks and regards,
Manas Pratap Singh
466
