Community Member
invalid MIC from Mobile Device
Hello guys,
i have two media tablets same hardware same driver. One is working proper and the other one is not able to associate with my ssid.
the debug out shows the follow:
*dot1xMsgTask: Feb 06 14:51:25.007: a8:54:b2:00:8b:34 Starting key exchange to mobile a8:54:b2:00:8b:34, data packets will be dropped
*dot1xMsgTask: Feb 06 14:51:25.007: a8:54:b2:00:8b:34 Sending EAPOL-Key Message to mobile a8:54:b2:00:8b:34
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_4: Feb 06 14:51:25.027: a8:54:b2:00:8b:34 Received EAPOL-Key from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:25.027: a8:54:b2:00:8b:34 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:25.027: a8:54:b2:00:8b:34 Received EAPOL-key in PTK_START state (message 2) from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:25.027: a8:54:b2:00:8b:34 Received EAPOL-key M2 with invalid MIC from mobile a8:54:b2:00:8b:34 version 2
*osapiBsnTimer: Feb 06 14:51:26.173: a8:54:b2:00:8b:34 802.1x 'timeoutEvt' Timer expired for station a8:54:b2:00:8b:34 and for message = M2
*dot1xMsgTask: Feb 06 14:51:26.173: a8:54:b2:00:8b:34 Retransmit 1 of EAPOL-Key M1 (length 121) for mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:26.257: a8:54:b2:00:8b:34 Received EAPOL-Key from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:26.257: a8:54:b2:00:8b:34 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:26.257: a8:54:b2:00:8b:34 Received EAPOL-key in PTK_START state (message 2) from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:26.257: a8:54:b2:00:8b:34 Received EAPOL-key M2 with invalid MIC from mobile a8:54:b2:00:8b:34 version 2
*osapiBsnTimer: Feb 06 14:51:27.173: a8:54:b2:00:8b:34 802.1x 'timeoutEvt' Timer expired for station a8:54:b2:00:8b:34 and for message = M2
*dot1xMsgTask: Feb 06 14:51:27.173: a8:54:b2:00:8b:34 Retransmit 2 of EAPOL-Key M1 (length 121) for mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:27.197: a8:54:b2:00:8b:34 Received EAPOL-Key from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:27.197: a8:54:b2:00:8b:34 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:27.197: a8:54:b2:00:8b:34 Received EAPOL-key in PTK_START state (message 2) from mobile a8:54:b2:00:8b:34
*Dot1x_NW_MsgTask_4: Feb 06 14:51:27.197: a8:54:b2:00:8b:34 Received EAPOL-key M2 with invalid MIC from mobile a8:54:b2:00:8b:34 version 2
*osapiBsnTimer: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 802.1x 'timeoutEvt' Timer expired for station a8:54:b2:00:8b:34 and for message = M2
*dot1xMsgTask: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 Retransmit failure for EAPOL-Key M1 to mobile a8:54:b2:00:8b:34, retransmit count 3, mscb deauth count 2
*dot1xMsgTask: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 Resetting MSCB PMK Cache Entry 0 for station a8:54:b2:00:8b:34
*dot1xMsgTask: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 Removing BSSID 34:db:fd:67:89:2a from PMKID cache of station a8:54:b2:00:8b:34
*dot1xMsgTask: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 Setting active key cache index 0 ---> 8
*dot1xMsgTask: Feb 06 14:51:28.173: a8:54:b2:00:8b:34 Sent Deauthenticate to mobile on BSSID 34:db:fd:67:89:20 slot 1(caller 1x_ptsm.c:546)
config of the SSID:
(Cisco Controller) >show wlan 6
WLAN Identifier.................................. 6
Profile Name..................................... Medientechnik
Network Name (SSID).............................. Medientechnik
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Disabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 1
Exclusionlist.................................... Disabled
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... KPSS_WLC1
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ medientechnik
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Enabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
--More-- or (q)uit
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
--More-- or (q)uit
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Disabled
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
--More-- or (q)uit
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
My understanding is that because of the invalid MIC the WLC interpret that the frames are corrupt ?
What could be the problem ?
Thanks for your help !!!!
Kind regards
Philip
1 ACCEPTED SOLUTION
VIP Purple
Re: invalid MIC from Mobile Device
HI philip,
As per this logs:
Means , you have entered the wrong pre shared key.
Just check again and  enter the correct key.
Reagrds
Dont forget to rate helpful posts
VIP Purple
HI philip,
As per this logs:
Reagrds
Community Member
yep thanks a lot problem resolved
customer.... told them three times to put in the key again
wlan & remote =! working weel ^^
cheers
Philip
VIP Purple
If this is resolved then can u marked as answered, it may help others.
Community Member
802.11n and Apple iPad, Cisco Cius tablet, and Apple iPhone 4
Each Wi-Fi enabled phone and tablet that supports 802.11n has specific antenna and channel configurations. Specifications for each device are listed on the manufacturer's website. Because these devices are 802.11n-enabled, they can use 802.11n enhancements such as MIMO and frame aggregation to help improve their upstream and downstream performance. The specifications for the Apple iPad, Cisco Cius, and Apple iPhone 4 follow:
• The Apple iPad is a one-spatial stream (single antenna) 802.11n-enabled device that operates in 2.4- and 5-GHz spectrums using 20-MHz channels.
• The Cisco Cius tablet is a one-spatial stream (single antenna) 802.11n-enabled device that operates in the 2.4-GHz spectrum using 20-MHz channels and the 5-GHz spectrum using 20- or 40-MHz channels.
• The Apple iPhone 4 is a one-spatial stream 802.11n-enabled device that operates in only the 2.4-GHz spectrum using 20-MHz channels.
How to Optimize 802.11n WLANs to Support Wi-Fi Enabled Phones and Tablets
The following steps are recommended to help optimize a Cisco Unified Wireless Network 802.11n deployment to more effectively support the Apple iPad, Apple iPhone 4, Cisco Cius tablet, and other Wi-Fi phones, tablets, or clients with similar wireless profiles.
Basant,
Good response. Just one note the newer iPads are 2x2:2 ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
!--- This signals the start of validation of message 4 (MIC), which
!--- means client installed the keys. Potential errors after this message
!--- are MIC validation errors, invalid key types, etc.
560
