10-10-2013 01:56 AM - edited 07-04-2021 01:03 AM
Hi Experts ,
I have unfied wireless LAN and we have nealry 200 windows users with 5500 controller and 3500 AP's .
However we have Ipad for some of the users recently who are facing issue with wireless bandwidth ...they are getting around 1-2 mbps ...not sure why ?
Do i need to modify anything in controller for this issue ?
Thanks ,
Vinod
10-10-2013 02:53 AM
Provide the following output of your WLC. Then we can tell you if anything to be modified
show 802.11b
show 802.11a
show wlan
Rasika
10-10-2013 04:08 AM
Hi Rasika,
Thanks for your reply ...
(Cisco Controller) >show 802.11b
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
11nSupport....................................... Enabled
802.11b/g Operational Rates
802.11b/g 1M Rate............................ Mandatory
802.11b/g 2M Rate............................ Mandatory
802.11b/g 5.5M Rate.......................... Mandatory
802.11b/g 11M Rate........................... Mandatory
802.11g 6M Rate.............................. Supported
802.11g 9M Rate.............................. Supported
802.11g 12M Rate............................. Supported
802.11g 18M Rate............................. Supported
802.11g 24M Rate............................. Supported
802.11g 36M Rate............................. Supported
802.11g 48M Rate............................. Supported
802.11g 54M Rate............................. Supported
802.11n MCS Settings:
MCS 0........................................ Supported
MCS 1........................................ Supported
MCS 2........................................ Supported
MCS 3........................................ Supported
MCS 4........................................ Supported
MCS 5........................................ Supported
MCS 6........................................ Supported
MCS 7........................................ Supported
MCS 8........................................ Supported
MCS 9........................................ Supported
MCS 10....................................... Supported
MCS 11....................................... Supported
MCS 12....................................... Supported
MCS 13....................................... Supported
MCS 14....................................... Supported
MCS 15....................................... Supported
MCS 16....................................... Supported
MCS 17....................................... Supported
MCS 18....................................... Supported
MCS 19....................................... Supported
MCS 20....................................... Supported
MCS 21....................................... Supported
MCS 22....................................... Supported
MCS 23....................................... Supported
802.11n Status:
A-MPDU Tx:
Priority 0............................... Enabled
--More-- or (q)uit
Priority 1............................... Disabled
Priority 2............................... Disabled
Priority 3............................... Disabled
Priority 4............................... Enabled
Priority 5............................... Enabled
Priority 6............................... Disabled
Priority 7............................... Disabled
Aggregation scheduler.................... Enabled
Realtime Timeout..................... 10
A-MSDU Tx:
Priority 1............................... Enabled
Priority 2............................... Enabled
Priority 3............................... Enabled
Rifs Rx ..................................... Enabled
Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mode................................. Disabled
CF Poll Request mandatory........................ Disabled
--More-- or (q)uit
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 1
Default Tx Power Level........................... 0
DTPC Status..................................... Enabled
Call Admission Limit ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
Fragmentation Threshold.......................... 2346
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
Faster Carrier Tracking Loop..................... Disabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC - Admission control (ACM)............ Disabled
Voice Stream-Size............................. 84000
--More-- or (q)uit
Voice Max-Streams............................. 2
Voice max RF bandwidth........................ 75
Voice reserved roaming bandwidth.............. 6
Voice CAC Method.............................. Load-Based
Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
SIP based CAC ................................ Disabled
SIP Codec Type ............................... CODEC_TYPE_G711
SIP call bandwidth: .......................... 64
SIP call bandwidth sample-size ............... 20
Video AC - Admission control (ACM)............ Disabled
Video max RF bandwidth........................ Infinite
Video reserved roaming bandwidth.............. 0
Best-effort AC - Admission control (ACM)...... Disabled
Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP................. 200
802.11a Network.................................. Enabled
802.11a Low Band........................... Enabled
802.11a Mid Band........................... Enabled
802.11a High Band.......................... Enabled
802.11a Operational Rates
802.11a 6M Rate.............................. Mandatory
802.11a 9M Rate.............................. Supported
802.11a 12M Rate............................. Mandatory
802.11a 18M Rate............................. Supported
802.11a 24M Rate............................. Mandatory
802.11a 36M Rate............................. Supported
802.11a 48M Rate............................. Supported
802.11a 54M Rate............................. Supported
802.11n Status:
A-MPDU Tx:
--More-- or (q)uit
A-MSDU Tx:
CF Pollable mandatory............................ Disabled
Default Channel.................................. 36
TI Threshold..................................... -50
Voice AC:
Voice CAC Method ............................. Load-Based
SIP call bandwidth ........................... 64
SIP call bandwith sample-size ................ 20
Video AC:
Maximum Number of Clients per AP Radio........... 200
WLAN Identifier.................................. 4
Profile Name..................................... xxxxxxx
Network Name (SSID).............................. cccccccc
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status ....................... Disabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 114
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ clients
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... 10.x.x.x
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ 10.x.x.x 1812
Accounting.................................... Disabled
Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Enabled
TKIP Cipher............................. Enabled
AES Cipher.............................. Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
Auth Key Management
802.1x.................................. Enabled
PSK..................................... Disabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID IP Address Status
802.11u........................................ Disabled
Access Network type............................ Not configured
Network Authentication type.................... Not configured
Internet service............................... Disabled
HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
WAN Metrics configuration
Link status.................................. 0
Link symmetry................................ 0
Downlink speed............................... 0
Uplink speed................................. 0
--More-- or (q)uit
Mobility Services Advertisement Protocol....... Disabled
Please do let me know if I need to modify anything ....
10-10-2013 11:11 AM
Hi Vinod,
I can see few modifications you have to do. Keep in mind thess changes will disturb users and therefore you have to do this during a maintenance outage window.
1. At the moment you have enable all low-data rates which is not a good thing. disable all data rates below 11Mbps. You can do that using following CLI commands on WLC (you can do this via GUI as well)
config 802.11b disable network
config 802.11b rate disabled 1
config 802.11b rate disabled 2
config 802.11b rate disabled 5.5
config 802.11b rate disabled 6
config 802.11b rate disabled 9
config 802.11b rate disabled 11
config 802.11b rate mandatory 12
config 802.11b enable network
config 802.11a disable network
y
config 802.11a rate disabled 6
config 802.11a rate disabled 9
config 802.11a enable network
2. You have disabled WMM on your WLAN network, which mean your client cannot get 802.11n speeds even though controller is supported these data rates. So you have to enable it.
config wlan disable 4
config wlan wmm allow 4
config wlan enable 4
3. Under WLAN security you have enable WPA/TKIP & WPA2/AES. I would leave it only for WPA2/AES. If client associate WPA/TKIP, then they can't get 802.11n speeds. To support 11n speeds you should have WPA2/AES & WMM enabled.
Once you do this test it again & see. You should have improved results
Rasika
**** Pls rate all useful responses ****
10-10-2013 12:41 PM
With QoS, bandwidth can be managed more efficiently across LANs, which includes WLANs and WANs. This is how QoS provides enhanced and reliable network service:
Cisco Unified Wireless Products support WMM, a QoS system based on the IEEE 802.11e draft that has been published by the Wi-Fi Alliance.
The controller supports four QoS levels:
Platinum/Voice—Ensures a high quality of service for voice over wireless.
Gold/Video—Supports high-quality video applications.
Silver/Best Effort—Supports normal bandwidth for clients. This is the default setting.
Bronze/Background—Provides the lowest bandwidth for guest services.
10-11-2013 12:06 AM
Hi ,
Thank you so much for replying with all the details ....
I will go ahead schedule the maintenance window for making above changes and revert you with the result.
10-11-2013 12:35 AM
No worries... if that works rate our responses & mark this post as "answered" .....
Rasika
10-15-2013 12:10 AM
Hi ,
Unfortunately we are getting the same speed i.e.1 Mbps .
Is there any settings to be changed in iPad devices ....
10-15-2013 12:32 AM
Try to download a file from your local LAN to a wireless device. That will prove the connectivity speed from wireless client to AP. In the above we do not know where the bottleneck is.
Anyway when you getting the above low performance please get the output of "show client detail
Rasika
10-15-2013 01:01 AM
Hi ,
Please find details below for client data rates :
Client MAC Address............................... 38:0f:4a:x:xx:xx
Client Username ................................. SHAxxx
AP MAC Address................................... 44:e4:d9:84:ed:40
AP Name.......................................... INccccccccc
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 4
802.11u.......................................... Not Supported
BSSID............................................ 44:e4:d9:84:ed:4d
Connected For ................................... 2063 secs
Channel.......................................... 149
IP Address....................................... 10.x.x.x
IPv6 Address..................................... fex,x,x,6
Association Id................................... 2
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... No CCX support
Re-Authentication Timeout........................ 84350
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
APSD ACs....................................... BK BE VI VO
Power Save....................................... OFF
Current Rate..................................... m7
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. 0a411e1200016387525cea01
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Management Frame Protection...................... No
EAP Type......................................... EAP-TLS
Interface........................................ xxxxx
10-15-2013 01:57 AM
Hi Vinod,
As you can see your iPad client is connected m7 (MCS7) data rates. Since iPad support single spacial stream this would be around 65Mbps. Even if your AP support multiple streams (2 in case of 3502) because of client limitation you cannot go anything above MCS7. (See below chart for detail)
In conclusion, your iPad connect to your wireless at least 65Mbps. Therefore it is not the bottleneck. If you doing this testing with internet, better to check what is the throughput you get on that service. Definetely issue is not wireless speed client get connected.
Without enabling WMM & WPA2/AES, you will never get these 802.11n data rates.
Hope it clears
Rasika
10-15-2013 05:05 AM
Edit: didn't see the other post
Repost your updated show WLAN
10-15-2013 05:11 AM
Hi Scott,
Please output below :
Network Name (SSID).............................. xxxxx
Number of Active Clients......................... 84
WMM.............................................. Allowed
Radius Servers
Authentication................................ 160.x.x.x 1812
Security
WPA (SSN IE)............................... Disabled
Auth Key Management
10-15-2013 01:26 PM
Install iPerf App onto your iPad, setup PC as a server on your LAN, see what speed you get from WiFi. You may get supprised.
10-21-2013 12:31 PM
Go to Wireless > Access Points > Global Configuration.
On the middle right side, set the Global TCP Adjust MSS to 1363.
Let me know if this helps.
