IPhone and MAC books are not connected to wifi with Cisco 1142 Autonomous AP
HI,
We are having Cisco 1142 AP ( Standalone) configured with WPA2 authentication and ACLs for MAC filtering.
All Dell laptops and Samsung android phones connecting without any issue.
But, we are having issue with IPhones, Apple MAC books . They are not connecting.
Advise me for next action.
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA6, RELEASE SOFTWARE (fc1)
BG7WIFI6006.AMS uptime is 9 minutes
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1142N-N-K9     (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1722E0UD
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 6C:41:6A:CA:74:D4
Part Number                          : 73-12836-06
PCA Assembly Number                  : 800-33767-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17194N00
Top Assembly Part Number             : 800-33775-05
Top Assembly Serial Number           : FTX1722E0UD
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-N-K9
Configuration register is 0xF
Janardhan
You've only given details of the AP, have you tried stripping the security back and seeing if they can connect.  Are they authenticating?
I do notice you are using an old version of software, you may want to check the release notes to see if you can find something specific:
http://www.cisco.com/en/US/products/ps6973/prod_release_notes_list.html
Chris
Hall of Fame Super Gold
Try OPEN authentication and then ramp up the security and encryption until you break them.
Hall of Fame Super Silver
Re: IPhone and MAC books are not connected to wifi with Cisco 11
You should post your whole show run-config. That helps us make sure your configurations are correct.
-Scott
I am having the same issue, did you figure out why
You need to provide more information.
362
