Iphone4 h-reap connection failure
I have 24 other devices quite happily associated with either of the two h-reap AP's (1130) on a 2112 WLC[6.0.202.0].
I cannot get a couple of Iphone 4's to connect.
I have looked at the debug attached and believe the problem might be with DHCP.
To get this far I had to increase the EAPOL-timeout to 5000mS.
I hope you can suggest something which will help connect these devices.
Richard
Everyone's tags (5)
Hall of Fame Super Silver
How is the wlan ssid configured?  Make sure that you either only have wpa/tkip or wpa2/aes configured, not both at the same time.
-Scott
Scott
WLAN only configured for WPA2/AES.
Richard
I have never had any issue with my iPhone connecting.  Did you verify the iPhone confiuration and that they didn't fat finger the key?
-Scott
Scott
Tested that on a non-hreap connection and got "Received EAPOL-key M2 with invalid MIC from mobile" message for that.
Non-Hreap Iphones connect ok.
Only appears to be certain Iphone4s on the h-reap AP's as there are 6-Intel, 7 RIM, 5 Apple and an HTC mac addresses connected perfedctly well.
The other change I tried was to disable client load balancing.
Richard
Well... you shouldn't use that client load balancing anyways.  That will cause you more grief.  I don't know what else you can do as I have no issues with mine on h-reap..
-Scott
531
