02-01-2007 10:08 AM - edited 07-03-2021 01:33 PM
I have a considerable number of access points to convert. All of the access points are new, so they have the MIC from Cisco. So I should be able to just TFTP the image onto the access points, but I can't find any info on this.
This would be considerably faster for me as I could do tens of AP at a time, and I wouldn't have to deal with the rather flaky upgrade tool. Has anyone done this before?
Solved! Go to Solution.
02-01-2007 03:04 PM
Actually you can do it. The main purpose of the Upgrade tool is to generate a SSC and add the SSC string to the controller. If you already have a MIC, the upgrade tool bypasses the SSC generation process and performs TFTP. You can telnet to an IOS AP and run
"archive download-sw tftp://x.x.x.x/c1240-rcvk9w8-tar.123-11.JX1.tar"
and the IOS based AP when rebooted will load the basic LWAPP code, join the controller and upgrade itself to match the controller's code revision. Now I don't know if this is supported, but your original question pertained to the possibility. So yes it can be done without the upgrade tool provided you have an AP with MIC installed.
Good luck.
02-01-2007 02:07 PM
Hi Shannon,
Unfortunately the upgrade tool is the only supported method :( You can upgrade 6 AP's at a time I believe. You can also have the tool setup on multiple machines,to expedite the process. The newer LWAPP Upgrade Tool shouldn't be as flaky as the earlier versions;
Customers have two options when migrating from Cisco Aironet autonomous access points to lightweight access points: using the software upgrade tool or trading out their existing autonomous access points.
The Autonomous to Lightweight Mode Upgrade Tool supports a process to migrate an autonomous access point from autonomous mode to lightweight mode. Unlike a VxWorks to Cisco IOS- Software upgrade, this process is a Cisco IOS Software upgrade to the existing Cisco IOS Software image-not an operating system "swapout". In converted access points operating in lightweight mode, Cisco IOS Software continues to run on the access point, while LWAPP is used to communicate with a wireless LAN controller.
From this doc;
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_white_paper0900aecd804f1a23.shtml
Hope this helps!
Rob
02-01-2007 02:18 PM
Yes, I've used it a bunch, but I'm getting ready to flash a whole bunch of access points and I was hoping I could get away from using the tool. I figured I would be much faster.
02-01-2007 03:04 PM
Good luck.
02-01-2007 03:06 PM
Cool. Thanks!!!
02-02-2007 04:35 AM
I was able to flash a hundred or so access points using this method last night. Worked great.
02-03-2007 12:31 PM
Hi Darren,
Very, very helpful info here! 5 points from me on this great answer :)
Thanks again,
Rob
03-01-2007 06:00 PM
Yes this does work, but how do you verify that 1200 series APs are of the post-7/05 MIC-enabled variety and don't need the Upgrade Tool? I'd love to use the WLSE for this but the TAC could not provide me with any means to verify this (like hardware serial number). Is anyone in the know about this? Thanks!
03-01-2007 07:03 PM
I don't have a 1200 with MIC handy, but there should be some evidence of the cert somewhere on the flash. I have a 1200 pre MIC that was converted and then unconverted. I have a SSC file in the NVRAM.
1200-test#dir nvram:
Directory of nvram:/
27 -rw- 2119
28 ---- 5
1 -rw- 0
2 ---- 11938
Perhaps you might have something similar on the NVRAM that would be an indicator?
03-02-2007 04:39 AM
You should be able to use WLSE to do the upgrades on the MIC enabled, but I don't know how you would verify that they had the MIC.
03-03-2007 02:11 PM
FYI -
The TAC offered the following undocumented command to verify the existence of a MIC on 1200/1230 APs:
test pb display
ap5#test pb display
Display of the Parameter Block
Total Number of Records : 7
Number of Certs : 6
Number of Keys : 1
If the AP outputs any information then it has the MIC; if it returns nothing it does not.
The AP has to be running 12.3.7 or later to run this command.
03-03-2007 12:25 AM
Hi Dv,
This is regading access point conversion from autonamus to lightweight,I tried with above method.Its giving follwing error
'AP-IOS-GRB8-IN-9#$nload-sw tftp://10.163.25.74/c1200-rcvk9w8-tar.123-11JX1
examining image...
%Error opening (Permission denied)archive download: takes 0 seconds
AP-IOS-GRB8-IN-9#'
I have alredy disable my lap firewall and antivirus also,I have small doubt,will this method will work from diffrent N/W if there is a N/W route or we have to do from AP management VLAN ? Also pls let me know how we can go ahead with MIC installation.
Regds
Saji k.s
