Is it possible to do multiple ssids and encryptions on an autonomous AP without vlans?
I got a customer who just has autonomous APs. They are upgrading from 1210s to 1262s. They are currently running a config that is wide open with no authentication or encryption and using a VPN tunnel on the wireless clients for security. They want to switch to using WPA2/PSK with the new APs. They have existing clients that have to continue to work during the upgrade to the new APs. They run 3 shifts so it is a 24 hr operation with no downtime. What I was thinking would be to configure the 1262 with multiple SSIDs, one with their existing settings and one with the new. Then I could swap the APs one at a time and it would only impact service for a short period of time while I was mounting the new AP. Then once all the new APs are installed I could transition the clients over to the new SSID and encryption then disable the old SSID once all the clients are switched over. I've done this before with a WLC but not with an autonomous APs. The only config examples I can find uses VLANs. This customer is not using VLANs. Is there anyway to use multiple SSIDs with different encryption on a single radio on an autonomous 1262 without VLANs?
The site has about 30 APs and 100 clients. Yes I know a controller would be preferred for a site of this size but that is a question for sales and why they didn't see them a controller. I just get stuck with what they sell them.
thanks
1 REPLY
Hi Don,
Im afraid on the autonmous platform you can not map multiple WLANS to a single vlan.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
101
