Community Member
Is my AP801 Config optimal for range and throughput?
All,
Can somebody check my AP801 config to see if there are any changes I can make to improve range and throughput?  The AP801 is built into my 881W.  The AP is running IOS v 124-10b.
Thank you!
James
version 12.4
no service pad
hostname ap
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
dot11 ssid YYYYYYY
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 0 ZZZZZZZZZZZZZZZZZZZZZZZZZZZ!
username Admin privilege 15 password 0 XXXXXXXXXXXXXXXXXXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid YYYYYYYYYYYYYYYY
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner login ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
end
714
