ISE and WLC SRE module compatibilty matrix
Hi all,
We are running SRE module on router with code of 6.x release .Is there any compatibilty matrix available for ISE and WLC code to support CWA . because as of now , the wireless clients are not redirecting to the ISE login page.
Kindly suggest.
Vijay
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: ISE and WLC SRE module compatibilty matrix
The doc is for wireless guest using CWA. For wired guest, I don't know since you can do wired guest from a WLC that supports it or from a switch.
-Scott
I believe WLC v7.2 and later is supported by ISE when using CWA.
-Scott
This might help
https://supportforums.cisco.com/docs/DOC-26442?referring_site=facebook&channel=CiscoSupportCommunity
-Scott
Hi Mr.Scott ,
Thnks a lot for your quick response . Is this will be applicable for both wired guest users CWA and wireless guest users CWA..
Vijay.
-Scott
http://www.cisco.com/en/US/products/ps11640/products_configuration_example09186a0080ba6514.shtml
-Scott
125
