issu in dot11 radio interface
i have a cisco access point like air-1230b-a-k9
in this ap ios was curropted.when i tried it was successfully load the ios via xmodem. but when i boot it from flash it showing that firmware for dot11radio 0 is not found.image 5001 is not found. what i have to do with this problems
1 REPLY
Bronze
Re: issu in dot11 radio interface
You can view a list of the contents of a file system before manipulating its contents.
For example, before copying a new configuration file to Flash memory, you might want to verify
that the file system you can use this command
show file system - display Display more information about each of the files on a file system
131
