Community Member
Issue configuring 2 APs (1250 and 1232)
Hi!
I am trying to setup an older 1232 Aironet as a repeater. I could not get this to work after countless hours of messing around with all the settings. This was going to be a non-ethernet repeater config. I finally decided to hardwire the 1232 to the switch. The whole purpose of this is to extend my wireless network. I now have the 1232 and 1250 going through the switch/router. I have not had any issues with the 1250--everything is setup just fine aside from the connectivity issues beyond a certain distance.
The main issues with the 1232 is that it does not support WPA2 (to my knowledge). The 1250 was setup with WPA2, but was demoted to WPA in order to work with the 1232. Putting the 1250 to WPA or WPAv1 prevented me from connecting to the SSID altogether.
I have also attempted to mess with the VLAN and the Network ID fields; thinking to put the same ID for the 1232 and 1250. No success on anything. The goal is to have the 1250 as the primary, and the 1232 simply to extend the capbility of the 1250. Can someone advise as to what specifically must be done? Both APs are on the same plane..essentially not a true line of sight since a wall separates them, but they are both now hardwired.
Thanks in advance!
Leo
Everyone's tags (2)
VIP Purple
Re: Issue configuring 2 APs (1250 and 1232)
Hi Leo,
First try to get your Repeater working with open authentication. Repeater AP need to connect to Root AP on the vlan configured as native vlan. Below post should be help you on this.
http://mrncciew.com/2013/01/20/autonomous-ap-repeater/
Once this is working, you can add WPA/TKIP as security (as WPA2 is not supported on your 1232) mechanism later on as shown in the below.
dot11 ssid
   authentication open
   authentication key-management wpa
   wpa-psk ascii
interface Dot11Radio0
encryption mode ciphers tkip
interface Dot11Radio1
Rasika
**** Pls rate all useful responses ****
Community Member
Thank you for your response! I am still experiencing issues, mainly from what I am seeing, due to the AP 1232. I think it would be best to get another 1250, if not later due to the encryption and many other features.
Once I do acquire another 1250 or later, should I just mirror the settings in terms of setting the SSID, etc. What would be the best method to setup the additional 1250 as 'repeater' / but maintain it being hard-wired (since it is currently feasible to do so). My goal is the same, to extend the capability and integrity of the wireless (failsafe is other AP goes down).
Thanks again for your help!
Leo
VIP Purple
Hi Leo,
Yes, it is good idea if you can find something like this. Then you can configure WPA2/AES & you can get 802.11n data rates as well (ie higher throughput for clients since 1250 supports that)
What do you mean by this ? Do you want this additional 1250 to be connected to the network via wired ethernet cable ?
Pls clarify this
Rasika
Community Member
Yes, I agree with the benefits of having the 1250. I would prefer to have the 1250 connected via cable to the switch. Do you agree that this would be the best method, or should it be setup as a repeater stand alone AP without the cable to the switch? I am going for best throughput as well as range.
VIP Purple
Hi Leo,
Yes, if you could connect AP to a wired switch that is the best you could get (typically repeater is used where you cannot extend wired connection for AP connectivity & backhall via wireless where bandwidth get drastically drop for client connections)
So what you should do is configure your SSID on both 125s 2 in same manner with WPA2/AES as auth/encryption. This will provide higher througput where you can get 802.11n speeds. Also it will give smooth roaming as long as you keep the config consistant & using PSK with WPA2.
Here is a simplest configuration example if you require a single SSID. You can simply configure your switch port as Access vlan with DHCP enabled on that vlan.(clients & ap will get same range IP)
hostname
dot11 ssid
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii
encryption mode ciphers aes-ccm
ssid
no shutdown
ssid
no shutdown
interface BVI1
ip address dhcp
If you want to configure multiple SSID then you have to create different bridge groups with sub interfaces on radio & gig interface. In this case your switchport should be configured as trunk & set native vlan as AP-Mgmt vlan (vlan 10 in below example)
hostname AAP1
dot11 ssid WLAN-1
   vlan 7
   authentication open
   wpa-psk ascii WLAN-1-KEY
   mbssid guest-mode
dot11 ssid WLAN-2
   vlan 8
   authentication open
   wpa-psk ascii WLAN-2-KEY
  mbssid guest-mode
encryption vlan 7 mode ciphers aes-ccm
encryption vlan 8 mode ciphers aes-ccm
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
ssid WLAN-1
ssid WLAN-2
mbssid
station-role root
interface Dot11Radio0.7
encapsulation dot1Q 7
bridge-group 7
interface Dot11Radio0.8
encapsulation dot1Q 8
bridge-group 8
interface Dot11Radio0.10
encapsulation dot1Q 10 native
bridge-group 1
interface Dot11Radio1.7
bridge-group 7
interface Dot11Radio1.8
bridge-group 8
interface Dot11Radio1.10
bridge-group 1
interface GigabitEthernet0.7
bridge-group 7
interface GigabitEthernet0.8
bridge-group 8
interface GigabitEthernet0.10
bridge-group 1
interface BVI1
ip address 192.168.10.254 255.255.255.0
ip default-gateway 192.168.10.1
**** AP Connected Swtichport *****
int g x/x
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allow vlan 7,8,10
Rasika
***** Pls rate all useful resposnes ****
1544
