lap
Issue converting a 881W from LWAPP to Autonomous mode
Hi everybody,
It may stupid but I was trying to upgrade the IOS image of the AP and I did a wrong manip.
I downloaded the IOS image (ap801-rcvk9w8-tar.124-10b.JA3.tar) from my TFTP server to the flash of the AP. Everything went find so far.
But than I did an archive archive download-sw /overwrite ap801-rcvk9w8-tar.124-10b.JA3.tar and my AP reboot in LWAPP mode.
I should have done: archive download-sw /overwrite tftp://10.0.0.1/ ap801-rcvk9w8-tar.124-10b.JA3.tar instead!
Now I don't how to go back to autonomous mode. archive commando is not available anymore in LWAPP mode.
Any ideas?
Best regards,
Laurent
lap
Re: Issue converting a 881W from LWAPP to Autonomous mode
A bit more details to my previous post to help you troubleshoot my issue.
On the router (881W) I did :
881W#service-module wlan-ap 0 reset bootloader
so I could access the bootloader of the AP. Now I have the following prompt:
ap:
I did format all the flash with this commando:
ap: format flash:/
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
flashfs[0]: 0 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31481856
flashfs[0]: Bytes used: 1024
flashfs[0]: Bytes available: 31480832
flashfs[0]: flashfs fsck took 43 seconds.
Filesystem "flash:" formatted
But now I don't know how to load the correct IOS image on the AP to go back to autonomous mode. Any ideas?
Best regards,
Laurent
lap
Well actually I solve the problem. I just want to explain what I did for people who are running in the same kind of problem.
First of all in the AP bootloader I did:
ap: ether_init
Initializing ethernet port 0...
ap: tftp_init
tftp_init success: You can now use tftp file system!
ap: flash_init
Than I checked the IP address of the AP:
ap: set
DEFAULT_ROUTER=10.0.0.1
IP_ADDR=10.0.0.1
NETMASK=255.255.255.224
Than I configured my PC on the same subnet and on the router I configured the switchport F0 to be on the same subnet as the AP:
interface FastEthernet0
switchport access vlan 2
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan2
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan2
ip address 10.0.0.2 255.255.255.224
Than I did in the bootloader:
ap: copy tftp://10.0.0.5/ap801-k9w7-tar.124-21a.JY.tar flash:/ap801-k9w7-tar.124-21a.JY.tar
where 10.0.0.5 is my PC IP where I have an TFTP server.
Once you have downloaded it you have to extract the image (Verify to download the right one. Not the LWAPP one) like that:
ap: tar -xtract flash:/ap801-k9w7-tar.124-21a.JY.tar flash:/
It can take a while.
Once it is extracted just type:
ap: boot
Than you should be find.
Don't forget to rate the post if you think it is useful.
Best Regards,
Laurent
Exactly what I was looking for. Thanks!
Thank you Laurent, very nice of you to spend time writing that process
Kind regards
Sanjeewa
Perfect. Thank you for your
Perfect. Thank you for your help. I applied this method to convert AIR-CAP2602E-A-K9 to Autonomous Mode witch image ap3g2-k9w7-tar.152-2.JB.tar.
I had a error:
Error writing flash://ap3g2-k9w7-mx.152-2.JB/Y5.bin (Not enough space on device)
I did format the flash with command: format flash:/
This process take very long time (1 hours), but is successfully.
2086
